High HP- Boost opinion
Old May 21, 2011 | 08:08 PM
LASTLS1's Avatar
6 Second Club Moderator
Default High HP- Boost opinion
30+ lbs of boost run a vacuum pump or not? I have both set ups. What's the best for the motor? 8000-8500 rpm wet sump.
Old May 21, 2011 | 08:10 PM
Phil99vette's Avatar
7 Second Club
Originally Posted by LASTLS1
30+ lbs of boost run a vacuum pump or not? I have both set ups. What's the best or the motor and hp? 8000-8500 rpm wet sump.
You definitely need a vacuum pump.
Old May 21, 2011 | 08:13 PM
LASTLS1's Avatar
Thanks Phil! I started putting it back together this afternoon. I need to find my notes from the last time we talked over the winter. I can't wait to get it out!
Old May 21, 2011 | 09:02 PM
qqwqeqwrqwqtq's Avatar
If you're going to use the vacuum pump lock down the pressure regulator on the pump and regulate it at the valve cover.
As it is now, if you get any oil in the separator it could still pull say, 10in vacuum between the pump and the separator but have 10psi pressure between the separator and engine.
Regulate it at the engine and you won't have that problem.
Old May 21, 2011 | 11:48 PM
LASTLS1's Avatar
I resolved the over flow problem. How much vacuum at wot?
Old May 22, 2011 | 08:38 AM
98Z28CobraKiller's Avatar
Restricted User
Why are you guys saying that a vac pump is required? You blowing oil out of the motor?
Old May 22, 2011 | 07:59 PM
LASTLS1's Avatar
No. But I'm going to turn up the wick and I have both set ups. Catch can is easy but if it helps the motor I'll put the vacuum pump back on. Some have said it's no big deal others say a vac pump is a must!
Old May 22, 2011 | 09:17 PM
Fbodyjunkie06's Avatar
I have heard David(mighty mouse) speak of making the breather set-ups work with a lot of boost. I haven't read much into this, does this only occur at high boost levels, or any and all just to a lesser degree?
Old May 22, 2011 | 10:41 PM
Snyper's Avatar
What I was thinking about doing(stop me if its a bad idea) but I have a catch can running to both valve covers and I was going to run a hose from the filter on the turbo to the port on the valley cover(since it has an oil separator) That way it will act like a vacuum pump when in boost..and any excess will go to the ccan.
