Fuel Pressure Regulator Help
Old May 21, 2011 | 08:35 PM
1INSANEGTO's Avatar
Default Fuel Pressure Regulator Help
Need some help fitting my requirements.
1:1 Boost Reference
It needs two -10 feeds and a -8 return.
100psi fuel pressure
Old May 21, 2011 | 10:45 PM
Motovative's Avatar
Fuel Labs
Old May 21, 2011 | 10:49 PM
black98ws6ta's Avatar
100 psi base or after xx amount of boost?
Old May 21, 2011 | 10:51 PM
KILLER-LS1's Avatar
im not sure what you need help with, finding parts that will work? or where to buy them?
Aeromotive makes a regulator with those size fittings...
Old May 22, 2011 | 04:00 PM
1INSANEGTO's Avatar
Aeromotive did not have one to those specs and was alot more money.
Think I am gonna go with a Weldon A2040 Fully adjustable from 4-200 psi two -10 fuel pressure ports -8 return port
For $244.00 shipped it a deal unless anyone else can tell me something better
Old May 22, 2011 | 05:13 PM
stevieturbo's Avatar
What fuel pump are you using to support 100psi ?
Old May 22, 2011 | 11:40 PM
1INSANEGTO's Avatar
Magnafuel prostar. Thinking of doing dual pumps.
Old May 23, 2011 | 12:03 AM
Why 100 psi? Sounds like belt drive fuel pump territory to me.
Old May 23, 2011 | 12:49 AM
NBM-LS1's Avatar
If you cant find one with -10 fittings couldn't you just find one with -8 fittings. Since its going to be at the end of the rails I figure you can use a -10 for the feed and a -8 for the return. you wont need a -10 return since the injectors will be using up some of the fuel. right?
Old May 23, 2011 | 03:53 AM
Their pump flow ratings are based on n/a setups, and current ratings at only 45psi.
Do they offer any data at higher pressures ?
Old May 23, 2011 | 05:55 AM
1INSANEGTO's Avatar
MP-4301 20–120psi 12A@45psi
Running -10 Feed -8 return
Running E85
