Gauges for pro charger car
I know i need a wide band sensor, boost sensor and fuel pressure gauge but i wanna keep it to a min.
so i was thinking that i could do a Aero Force gauge to monitor most of the stuff and put one gauge in the cubby hole right above the shifter. but i don't know which one i should run by its self and which i should run off the Aero Force
Im not stuck on any gauges but want to do it right the first time so please if anyone has suggestion please let me know or if i am missing a gauge or sensor that i should be monitoring
Granted if the car feels like it's down on power, yes, I'm going to log data and check to see what psi I'm making, which is a lot safer than trying to focus on a gauge while hammering it.
Lots of reasons to have a boost gauge. If you HAD to pick only 2, then go with WB and FP, but I'd recommend getting boost as well. I have all 3 plus an aeroforce interceptor to check out other miscellaneous parameters such as KR, timing, coolant temp, or whatever else the computer sees that I may be interested in at the time.
