So what actually destroys the motor?
Old May 29, 2011 | 02:44 AM
Madellous's Avatar
Default So what actually destroys the motor?
We all know that it is a good idea to forge the bottom end when going FI. I am new to turbos/sc and was curious what actually makes it dangerous to the stock motor? is it the HP/TQ numbers? or does it have to do with knock and not having a high enough octane fuel? I hope my question makes sense. I am trying to learn all the ins and outs of FI for my future build.
Thanks
Old May 29, 2011 | 03:04 AM
dkrowner's Avatar
a bad tune is the one i could think of
Old May 29, 2011 | 03:05 AM
stock48's Avatar
9 Second Truck Club
Yes I would say detonation it the #1 killer weather it be from poor octane fuel, bad tune, or faulty sensor, waste gate, or boost controller etc.
Old May 29, 2011 | 04:02 AM
Madellous's Avatar
so its more detonation than anything? knowing that its not the hp levels makes me more motivated to go FI. My biggest concern is safety so I will be getting a professional tune and not cheap out when i do the build in the future. thanks for the help
Old May 29, 2011 | 07:02 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
The stock piston ringlands seem to be the most susceptible to failure at high horsepower levels. It might not even be misfires but rather cylinder pressure once you start hitting high torque numbers. I'm not sure even the safest tune can save a stock motor making more than ~550-600 rwtq. Before too long, the pressure is just going to crank a ringland.
Old May 29, 2011 | 09:02 AM
OreoLt1's Avatar
Just happened to me last night. Pulled the drivers side head and #7 pistion broken from middle oil ring through compression ring to top. I knew what happened when I pulled the plug out and the tip was smashed
Old May 29, 2011 | 10:35 AM
BadgeZ28's Avatar
all of the above and pushing the block to far. At some point cylinder walls and other components flex, resonate, change shape. The iron blocks seem able to handle it to a higher level. If you want to build a monster use a aftermarket block as the foundation.
Old May 29, 2011 | 11:10 AM
tripblackls1's Avatar
i highly doubt this
aluminum block have been pushed past the 1k hp plenty of times (forged of coarse)
and then past these levels its not the block(aluminum or iron) that becomes a problem, its trying to keep the heads from pushing water and thats when you need 6 bolt heads and block
Old May 29, 2011 | 12:00 PM
js2fst's Avatar
Also too many rpm's. On any LS motor alot people try rod bolts. My opinion they are a waste of money. We had a c-5 with 547 rwhp we sold with over 138k miles na new owner raced everyweekend and spraying no problems with over 180 k miles. And I now have 527 rwhp with 80 k miles of boost.
Old May 29, 2011 | 01:12 PM
Reckless's Avatar
Super Moderator
For many of the folks that drag race or road race, it is the oiling system. the factory wet sump oiling system is great for a street car, but at high HP levels in a race application, the dry sump is the only option. The other items mentioned above are also common failure points. Certainly a really good tune is critical. Lifting heads will usually not result in losing your engine though, just some time to replace parts and retune.
Old May 29, 2011 | 03:33 PM
djfury05's Avatar
Originally Posted by tripblackls1
i highly doubt this
... I need to go pick up a forged aluminum block I knew I was forgetting something.. if your pushing water you need to o-ring the block.. if your lifting the heads you need to get 6 bolt heads/block
Old May 29, 2011 | 04:55 PM
serious? when i said forged i meant the rotating assembly not the block, i guess i need to go through and explain things thoroughly for ls1tech as some ppl are to slow to catch on
Old May 29, 2011 | 05:22 PM
ModularTurbo's Avatar
in this order:
1. Knock from bad tune.
2. Too much torque (aka too much timing at peak torque)
3. unequal flow to cylinders 5 & 7.
Old May 29, 2011 | 06:08 PM
djfury05's Avatar
it was sarcasm pal.. even with forged rotating assemblies the sleeves in an aluminum block still have their limits.. I think you need to go through and keep reading and learning before making retarded posts
Old May 29, 2011 | 06:43 PM
1fast bird's Avatar
-Detonation.....bad tune,computer glitch,bad gas etc......
-overpowering the rods/rod bolts.......Ask me how I know!!!
Old May 29, 2011 | 07:36 PM
lol its funny that your the one posting sarcasm and then say im making retarded post , perhaps i hurt your feelings?
maybe you should take a look at this before we continue http://www.time4learning.com/reading...prehension.htm
because obliviously you cant read, i never stated anything about stock sleeves and how much there good for, what i stated was that you will push water/lift heads before you have a problems with the block
now as far as the sleeves go ive seen some crack at very low hp(400-500) and some take as much as 1200 without a problem, so i believe its more of a tuning issue than anything else
and just a lil bit more info on the aluminum block subject there is erl sleeved blocks that are making close to 2k hp, so once aging i will say i doubt it is a problem having a aluminum block
now im sure your feeling are going to be hurt once aging so go ahead and pm if you would like to talk out of your *** some more
Old May 29, 2011 | 07:58 PM
djfury05's Avatar
so with your logic I should get 6 bolt heads and block if I'm pushing water and o-ring the block if I'm lifting my heads.. awesome I think I understand now.. thank you for the clarification
Please continue to be my humor for today's morning.. cheers
Old May 29, 2011 | 08:32 PM
Fbodyjunkie06's Avatar
A lean condition is the worst thing for a stock LS1 with boost. Higher boost pressures approaching 1 bar also spell trouble for the rods and bearings at rpm higher than 6500 RPM. My car is tuned to where when the boost comes on the AFR dives to 10.9-11.0 consistently every time. Even then I run 1-2 gallons of 110 with a full tank of 93 and 100% M1 Methanol in my boost cooler reservoir. I plan on putting a LQ4 or LS2 in the car once the motor goes, but I am shooting for high 9's before that happens hopefully.
