Help me With My Possible Turbo Buil
Old May 31, 2011 | 06:13 PM
1998MysticZ28's Avatar
Default Help me With My Possible Turbo Buil
Hey guys, I have been reading here, a lot lately. Recently the opportunity came up to buy a tubular manifold kit with a turbo(Ebay) and inter-cooler. This will not be on the car anytime soon, cause I want to buy everything I need first that way the car is not down for more than it has to be.
Specs on the camaro
Forged 347
LS6 Ported heads
232/236 114 LSA Cam
LS6 Intake with P/P TB
42# Injectors
Racetronix 255 pump (will add another)
Peformabuilt trans 3600 stall
4.11 Gears
Can I run that cam with low boost. I know my compression is 11.1. Do you guys suggest ditching the LS6 Intake and going with a Vic Jr.? Really not sure on which turbo I will be replacing this one with, or what wastegate and Blow off valve to get. Any help will be appreciated
Old May 31, 2011 | 06:36 PM
djfury05's Avatar
Your fine with the LS6 intake. I would look to try and find some cheap 317 heads and swap those for the 243s though to lower compression a bit. How much power are you looking to make? What are the details on the hotside of the turbo kit?
Old May 31, 2011 | 09:22 PM
Its the PTK reproduction kit. Honestly 6-8 psi is enough for my first turbo car I think.
Old May 31, 2011 | 09:55 PM
djfury05's Avatar
that's what you think lol.. that will equate to roughly 450-550 to the rear maybe.. that gets old quick
Old May 31, 2011 | 10:08 PM
haha I just want a good car with a nice power band. Can honestly careless about dyno numbers just fun to drive and goes like hell.. Do you think I can go up to 10 safely?
Old May 31, 2011 | 10:50 PM
westtexasbuff's Avatar
With a good tune, yes.
Old May 31, 2011 | 10:54 PM
cracker's Avatar
Good fuel is also key. 10lbs, 11+:1, and 87 octane is a recipe for disaster.
-Wade
Old May 31, 2011 | 11:24 PM
well the car only gets 93 or I can go e85
Old Jun 1, 2011 | 01:48 PM
djfury05's Avatar
If your just trying to be conservative I'd keep it around 7-8 lbs and don't spin the motor too high with 98' rod bolts.
