Turbo vacuum lines HELP!!!!!!!!!!
Old Jun 12, 2011 | 10:32 PM
BlackWS666's Avatar
Default Turbo vacuum lines HELP!!!!!!!!!!
Ok, I cant get this crap down to save my life, and ive asked people and nobody is 100% so im looking for someone to shed me some light here. Its a 60mm JGS wastegate, 60mm JGS BOV, magnafuel fuel pressure reg, and 3 bar map. Hope that helps. Here is a half-*** paint diagram. Is this right? If not please correct me. THANKS IN ADVANCE GUYS, cars not far from starting!!!
Also im planning on just running the motor without the boost controller(eboost2) for a bit to work out all the kinks/bugs. Will that be alright?
This will be ALL the vacuum lines in the car as i dont have power anything. So please fell free to also let me know if im missing something, or am going to run into a problem. THANKS
Old Jun 12, 2011 | 11:03 PM
Busy Mopper's Avatar
that looks right, but why is there a question mark with the bov? and what are u porting the lines with on the back of the intake.. i suggest u split the brake booster vacum line and get like a 5 or 8 way port
Old Jun 12, 2011 | 11:04 PM
trans2000am's Avatar
lmao bad *** drawing, your blow off has 2 ports for vacuum?
Old Jun 12, 2011 | 11:07 PM
the intake is prolly a aaron elbow, where is your brake booster line going?
Old Jun 13, 2011 | 12:15 AM
BlackWS666's Avatar
I have drag brakes on all corners. yes the BOV has 2 ports. yes its a 6061.com elbow.
The drawing took me like 7 minutes, haha.
Old Jun 13, 2011 | 07:57 PM
BlackWS666's Avatar
Anyone else? Had a buddy tell me today that the second(lower) port on the BOV should be ran in the intake pre-throttle body. And it really helps close/open it faster. Is this corrrect?
Old Jun 13, 2011 | 08:07 PM
HydroStream6's Avatar
That should work fine. Might want to move the wastegate to the manifold rather than the comp housing, but it'll work.
Old Jun 13, 2011 | 08:34 PM
JankesGTO's Avatar
Was gunna say the same thing... lower port on bov. Pick up vacuum direct from intake.
Old Jun 13, 2011 | 08:42 PM
BlackWS666's Avatar
Ok, guys thanks. Im gonna order all the crap from RPS, and start knocking this out.
Old Jun 13, 2011 | 09:53 PM
madmax4499's Avatar
Originally Posted by jankesgto
was gunna say the same thing... Lower port on bov. Pick up vacuum direct from intake.
what?
Old Jun 14, 2011 | 01:59 PM
JankesGTO's Avatar
Run line to question mark on bov not where you have it drawn.
