What compression ratio will I be at?
Old Jun 15, 2011 | 02:57 PM
smokinponcho73's Avatar
Default What compression ratio will I be at?
I have a 408 with stock l92 heads and -28cc pistons. I have not picked my head gasket yet but I think I will run like an .040" or something like that. i don't know any other factors that could help one determine the C/R. It is a 4.030 bore with an 4" stroke and 6.125 inch rods on a stock deck block.
Thanks Brandon
Old Jun 15, 2011 | 05:35 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
With stock 70cc chambers, assuming the piston is zero deck and running a .040" thick gasket you'll net about a 8.9:1 static compression ratio.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 15, 2011 | 08:40 PM
Thank you for confirming that. Thats what I thought.
