What's the best way to hold the MAP sensor in a FAST 90 intake?
I have a FAST 90 on my car and about to install a D1SC setup, and am going to swap out the MAP to the 2-bar sensor. I know the map sensor didn't sit to securly to begin with on the intake, so I used a little bit or rtv and it did fine, but that's NA where it only sees vacuum to ambient at best pressures. Now that I plan to see between 8-10psi of pressure, what is the best way to hold the map sensor in place?
I remember seeing on Hardcore someone had made a bracket to hold it in place, but unfortunately, I didn't save the picture.
Thanks guys.
Thanks guys.
