LSX alternator relocation kit
Old Jul 1, 2011 | 04:45 AM
  #121
ModularTurbo's Avatar
Yep we got 10 you guys are good to go.
Old Jul 1, 2011 | 04:52 AM
  #122
Group buy is over....
Old Jul 1, 2011 | 07:14 AM
  #123
chevymec's Avatar
Good deal!!
Old Jul 1, 2011 | 11:26 AM
  #124
MUSTANGBRKR02's Avatar
Sweet. When should we expect them?
Old Jul 1, 2011 | 11:32 AM
  #125
frcefed98's Avatar
bout time a excellent quality reloc bracket came to the market for a nice price, good job Modular turbo/cbr performance.
J
Old Jul 1, 2011 | 12:17 PM
  #126
Denali08's Avatar
Are they ready to ship?
Old Jul 1, 2011 | 02:13 PM
  #127
Island Grown's Avatar
nice. can't wait!
Old Jul 1, 2011 | 02:37 PM
  #128
Tramminc's Avatar
[QUOTE=nahasapeemapetalon;15083677]Got the (i think first bracket made)!
My mid 90's suburban alternator wasnt doing the job, voltage was always really low and my belt alignment wasnt very great.
I got a 145A truck alternator and used this Modular Turbo bracket. I have nasty nate fuel rails and just had to replace the passenger front rail fuel fitting with an NPT 90 to hose end fitting.
The bracket was well put together, seems really sturdy. Nice adjustable tensioner. No more belt squeal. So far so good.
I probably didnt need to modify the alternator back plastic cover but chose to for possible belt tightening.
14.0Volts FTW!! Nice work guys, thanks for the quick ship!
First thought was a gas leak at the 90 and spark from alt.
Old Jul 1, 2011 | 02:51 PM
  #129
evo462's Avatar
Wait, you got yours already? I paid two weeks ago and still haven't received mine.
Old Jul 1, 2011 | 09:10 PM
  #130
Chris@CBR's Avatar
He got the very first one.
I had just enough material in the shop to make 2 kits, he got the first one
and the other left right behind it.
It takes a few days to get the materials in the shop and a few days to get them made
powder coated and shipped.
5 kits got shipped USPS Thursday.
You may get yours tomorrow.
I have enough material in the shop now to make over 50 kits
Old Jul 1, 2011 | 09:35 PM
  #131
89ROC-Z's Avatar
^^ great i'd like to get it on before the dyno on the 9th.
Old Jul 1, 2011 | 10:59 PM
  #132
Chris@CBR's Avatar
89ROC-Z you have a PM
Old Jul 4, 2011 | 08:27 AM
  #133
When you guys get your brackets you will have to trim this piece down pictured below:
This is only on the F-Body/GTO alternator.
Old Jul 5, 2011 | 12:22 PM
  #134
89ROC-Z's Avatar
^^ shouldn't be a problem.
They ship out today?
Old Jul 5, 2011 | 12:49 PM
  #135
89ROC-Z's Avatar
Also, what gauge wire do you guys recomend to use to lengthen the stock alt wires? I'm sure the + from the bat will be plenty long
Thanks
Old Jul 5, 2011 | 01:20 PM
  #136
evo462's Avatar
Got my bracket installed. Here's a quick write up for install (though it's pretty self explanatory).
Tools needed:
Adjustable crescent wrench
Socket wrench with 9/16", 5/8", and 17mm (or 11/16") sockets
1) Cut the plastic "vent" off the back of the LS1 alternator. I made quick work of it with a Dremel and cutoff wheel.
2) Remove the factory tensioner using a 5/8" socket wrench.
3) Use the two shortest bolts (17mm) to affix the smaller bracket to the passenger side head.
4) Use the two fully-threaded bolts (17mm) to affix the larger bracket to the water pump housing.
5) Place the "ear" on the alternator into the open area on the top right side of the alternator bracket, and slide the 5" long bolt (17mm) through the opening and hand tighten. If you fully tighten it now, it'll make it harder to set the tension on the belt later.
6) Take the two remaining 3.25" bolts and insert one through the hole on the alternator, then the other through the hole on the alternator bracket.
7) Place the adjustable tensioner rod on the back of the 3.25" bolts and secure it using the 9/16" nuts. You may have to adjust the length of the tensioner rod to get it to fit.
8) Route the belt as shown below. I had to remove my oil filler cap and fully lower the alternator using the tensioner rod in order to slip the belt over the crank.
9) Lengthen the tensioner rod (9/16") to set the proper belt tension.
10) Once your tension is properly set, perform a final tightening on the top right bracket bolt (17mm") that runs through the ear on the alternator.
I haven't pulled the alternator wire out of the engine harness yet, so maybe Rob or Chris can chime in with more specific directions on that portion.
The bracket is very nice, install was straight forward, and setting the tension was easy. Nice work!
Old Jul 5, 2011 | 04:30 PM
  #137
Chris@CBR's Avatar
Be careful with that belt tensioner, you can easily over tighten the belt.
You will be able to put plenty of tenstion on the belt with out needing a 9/16 wrench.
Let me give everyone that has had there harmonic balancer off there motor a heads up.
It should a little more than 3-7/8" and less that 3-15/16. I put a set of calipers on it
and got 3.925. 3-7/8= 3.875 and 3-15/16= 3.9375.
I know these things can be hell to get seated all the way, this should help.
Old Jul 5, 2011 | 05:06 PM
  #138
98Z28CobraKiller's Avatar
Restricted User
Win! Another great product.
Old Jul 5, 2011 | 06:04 PM
  #139
Hopefully with all of these sales Rob can buy Chris a new tape measure...
Old Jul 5, 2011 | 08:01 PM
  #140
Chris@CBR's Avatar
You got that right!!!
Don't buy an auto lock with the lever on the bottom, the tape is always dragging.
I use this one to mark stock at the band saw.
