E-85 and 11.3:1 compression
Old Jun 22, 2011 | 06:52 PM
forgedlt4's Avatar
Default E-85 and 11.3:1 compression
i am going to try 9 lbs....
will i blow this thing up?
Old Jun 22, 2011 | 07:11 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
tuned right, should not be a problem.... e85 is good stuff
Old Jun 22, 2011 | 07:28 PM
forgedlt4's Avatar
im running a blow thru carb and locking the timing. NO intercooler.
my intake mani gets ICE cold after a drive. no ice, but tons of water sweating like the outside of a ice cold glass left out on a warm day.
its so hard to find info on safe compression ratios with boost online.
Old Jun 22, 2011 | 07:48 PM
HydroStream6's Avatar
There's guys running more (much) boost and more compression. Your mileage may vary.
Old Jun 22, 2011 | 08:08 PM
Grr's Avatar
Grr
not an issue, when you get in the 15# area you should be looking into an intercooler though.
Old Jun 22, 2011 | 11:45 PM
I_Need_Land's Avatar
iirc his dynamic compression ratio is in the 9.3-9.6 range. but that was with his stock lt1 cam. im unsure of what the new cams dcr is... care to post it up?
Old Jun 22, 2011 | 11:49 PM
kmracer's Avatar
why is your timing locked? you should have at least a 6AL-2.
but yes, you'll be very safe from what i've seen, not personal experience.
Old Jun 23, 2011 | 04:36 PM
forgedlt4's Avatar
because I am running some piece of **** summit digital ignition box that has been acting up.
