Meth inj ? best kit for a street car 15psi
just running a basic set up forged 347 ls6 top end ( heads cam and intake ) with a BW s475 turbo . looking for about #15 psi ( dnt plan on much more 650-700rwhp is goal for the car)running a ebay air to air and pump gas looking to pickup a meth inj system for safety/power gains
been looking at
snow performance stage 1 .. deff the cheapest at less than $300 bucks shipped (this is what im leaning for unless im steered other way)
alky control f body kit might be over kill for my street set up
aem meth dnt knw much about it .
plan on using the meth once i get over #10psi
and runing 50/50 prob washer fluid .
any suggestions would be great as i got money buring a hole in my paypal pocket and ready to order asap !
been looking at
LS1Tech Sponsor
The Alky Control system uses better components than many of the less costly brands, I recommend going with it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Last I checked it was around $600.00. Bob
__________________
is it really worth 2x as much more as the snow ?
for my requierments ? at most 15 psi dnt need any fancy 2 stages or progressive controller.
will be running a 50/50mix
anyone running a snow kit have any input ??
buy the cheapest one you can find and spend the extra money somewhere else.
they all use the same shure pump,same pressures, same nozzles, same fittings etc. probably the only difference is how they switch on the boost.
a water injection kit is a pump, and a boost switch . it is not complicated
I lokk for the best deal possible, so I made my own for my 87Grandnational, but I think Alky is a little pricey for my budget as of now. I got my pump from Devils Own. For this car I will get it from Devil.
I've got the snow methanol kit with the controller and purge. I like it, I have 5 different ramp settings I can choose from to either richen the tune up or lean it out.
BTW I run pure M1 instead of the washer fluid stuff. It really isn't all that great, it works, but M1 is a lot better to use because of the way it pulls heat from the intake tract.
yeah ended up just getting the snow . got it for 256 shipped ..
stayed on budget .. should work perfect for what i need out of my little drag radial street car !
thanks !
ill look into just the m1 stuff
thanks !
