need a different oil feed source for turbo
I need a place to get my oil feed from for my turbo...
i cant tap above the oil filter like i see commonly done, due to extremely tight header collector.. (gmc sonoma lsx)
what are the other locations...?
i was gonna try and "T" under the oil pressure send but not such good luck with hardware store fittings..
I used the oil galley plug on the front driver side of the engine. it's a 16mmx1.5 hole comes directly from oil pump.
this would work http://www.summitracing.com/parts/ATM-2268/
i can get that exact sleeve if you think thats the best, i already have some of the DEi fire sleeve. its iron oxide silicone coated fibergalss, and is rated for 500*F contact and 2000*F ambient...
i value your opinion. just asking because i have this brand sitting in front of me thats all
http://www.summitracing.com/parts/DEI-010474/
