valve cover breathers ok?
the 2 openings towards the firewall both have breathers. the pas side opening by the oil fill is capped off...
sometimes i see oil on the valve cover by the pass side breather filter.
is that normal? should i have this setup differently?
http://www.gmhightechperformance.com.../photo_60.html
http://www.gmhightechperformance.com.../photo_70.html
The drivers side valve cover already has a hole in the rear, but I drilled and tapped the passenger side cover, ran -10 lines from each one, T'd it into a single -10 line and into a vented can.
Maybe I'll tap and drill for another large fitting in my catch can and run a line from there to my downpipe. Might not have as much vacuum as the intake but you would eliminate the problems with PCV and still be getting out a lot of vapor and gas from the crankcase.
Dont have to deal with catch cans, breathers or any of that nonsense.
