Track Times for QMP Turbo Formula!!!!!
Old 03-01-2004, 11:42 AM
  #41
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Rob what rwhp was that 136 achieved with?? Looks like about 650rwhp or so?
Jose
Old 03-01-2004, 12:12 PM
  #42
Rob Raymer's Avatar
Jose
That's what I would guess. On the 136mph pass, I was running 11lbs of boost on the 13.5lb LS1Edit program, so it was a little too rich. I believe when we dynoed the car with that exact setup, it made 690rwhp??? (or very close to that anyway)
I'm sure that a lot of mph was lost in the off-idle "launch", and granny shifts.
Old 03-01-2004, 12:31 PM
  #43
NA$TY-TA's Avatar
Congrats Rob......... I cant wait to see how this kit does on a built 348.
Kyle
Old 03-01-2004, 02:30 PM
  #44
Rob Raymer's Avatar
I'm disappointed.....PSJ has posted on practically every thread but mine. He no like me no mo.....
Old 03-01-2004, 02:34 PM
  #45
Super Moderator
Reckless's Avatar
Better watch out Rob....Mike B's new motor is 347cid too, and he upgraded to 37mm turbos But wait until you see his other project
Old 03-01-2004, 03:26 PM
  #46
Rob Raymer's Avatar
I know...Mike told me! I personally can't wait to see it. I won't even try to compete with the other project.....it's outta my league. I have to get the Formula out of the 11's before I can even think about running 8's!
Old 03-01-2004, 03:32 PM
  #47
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
136mph looks pretty promising, I did read the thread through a few times. It's hard to say what the car would have done with an aggressive launch and harder shifting I would like to see that but if you were trying to keep stock components alive I can see that.
Old 03-01-2004, 03:55 PM
  #48
Rob Raymer's Avatar
Finally! PSJ noticed me!! Yes, I was definitely trying to keep stock components alive, just as I had said I was going to do.....idle launch, easy shifts, etc. It already did a lot more than some thought it would...namely made it down the track with all stock parts!
So what is the record for fastest (mph, not ET) stock LS1 F-Body?
What kind of mph are you expecting to see with your car first time to the track? Also, what was the weight of your car again? Just to compare.
And lastly, when and where are you going to run it? Maybe we can meet up.....I should be about done with the new setup by the end of next week I hope.
Old 03-01-2004, 04:08 PM
  #49
LS1Tech Co-Founder
Stock longblock MPH record is probably low 130 or so with a nitrous car but I'm not sure. Dave Purlee from IL once went 10.5 with a stock longblock a number of years ago but I don't recall the MPH.
I hope to be 3400 raceweight, but I might actually be more around 3500 we'll have to see. I hope to go 142 or better to beat your record in the Camaro.
Old 03-01-2004, 04:11 PM
  #50
Guido's Avatar
I cant wait to see that!
Old 03-01-2004, 04:32 PM
  #51
Rob Raymer's Avatar
Cool. So the 136mph blew that record out of the water, huh?
Wow...3400! I can only imagine. I would think at your HP level and weight, 142+ should come pretty easy actually. FWIW, you can beat that record if you want.....I don't own that car anymore. If I did, you'd need to run even more mph than that!
Old 03-01-2004, 04:48 PM
  #52
S_J_H's Avatar
Nice mph Rob. Shhhhh.. let's not disuss those ET's.
I have no idea if that's some sort of stock f-body mph record though.
I think comparing a m6 to an a4 or especially any th400/loose stall car will always show the m6 to trap much higher mph.
Heck when my car was bone stock in 98 it trapped 101mph. Buddys M6 trapped 107-108 same day bone stock.
I trapped 125MPH at near 3700lbs with 2.73 gears/a4, stock 98 cam/stock 98 ls1 heads,G-trim, lifting the heads/on/off/on the throttle at slippery dirty GLD.
Heck that must be some sort of record?
I'll bet your 136mph would be near 129-130 with a4,2.73 gears don't you think?
So I guess you still got me
But trap speed and dynos don't win races.
I plan on running 130+ and low 10's with the little step child of a blower G-trim. Not with 2.73's though.
No 9 sec car for me. But might be enough to make PSJ nervous if he can't hookup.
John, post when your going to run your car. I'd like to come check it out.
Steve
Old 03-01-2004, 11:12 PM
  #53
Mike 01WS6's Avatar
They do on the highways.....
Old 03-01-2004, 11:21 PM
  #54
Rob Raymer's Avatar
Yea, I think it's pretty obvious that if I was building a racecar, it wouldn't have AC, PS, Stereo, sway bars, full interior, a 6 speed, and weigh over 3700lbs.
Personally, I was only concerned with mph Saturday. And I was more than happy with the results. It may not have laid down a low ET at the track, but you wouldn't believe the power it has on the street. FWIW, almost too much power for the street.
Don't forget one other thing...I still have stock 3.42 gears in the car, but I was running a 28" tall tire. Making it more like a 2.73 gear by comparison. Looking back at it, I really was running the car against all odds Saturday.
Old 03-02-2004, 12:42 AM
  #55
2000 ws6's Avatar
Rob was seriously babying that car out of the hole, it looked like a stock civic for the first 20 feet than BOOM it was screaming, the reaction in the crowd and on peoples faces was priceless. I can't believe how quiet the car is either. Very sweet car.
Old 03-02-2004, 01:16 AM
  #56
01_SuperSlow's Avatar
Congrats Rob .
Old 03-02-2004, 07:59 AM
  #57
Tiago's Avatar
vulgar display of power
we want vids
Old 03-02-2004, 09:19 AM
  #58
CHRISPY's Avatar
SJH are you going with a 12 bolt?
Shoot me a pm so as not to clutter this thread.
Cheers,
Chris
Old 03-02-2004, 10:27 AM
  #59
MECHAM's Avatar
Originally Posted by Tiago
we want vids
Old 03-02-2004, 11:08 AM
  #60
S_J_H's Avatar
Smile
no your not even close to 2.73 gearing Rob. You would need a 33" tall tire to equal my 2.73 with 26.2" tires.
Trust me it takes some oats to pull these freeway gears. Of course you have the power and then some! No argument there. I was just pointing out it's difficult to compare trap MPH between differently equipped cars as a way of Illustrating the engines power.
Chris, 9" and spool.
Steve
Quick Reply: Track Times for QMP Turbo Formula!!!!!
