Most power with a 5.3
Old Jul 1, 2011 | 02:54 PM
YouGotJunk's Avatar
Talking Most power with a 5.3
Just want to hear about some peoples 5.3 builds. What's the most power you've made with an iron block 5.3 and a turbo? I'm building a stock bore iron block 5.3 with a stock crank and aftermarket rods and pistons. My compression should be around 9-9.5:1. I'll be running a stock set of 317 heads with good springs and most likely a custom grind turbo cam...or is there an off the shelf cam that would work good?? Ill be running a Borg warner S475 turbo with a 75mm compressor wheel and a 1.32 a/r with a t6 flange. Might run it on the street on e85 and possibly q16 at the track. This will be ran with a built powerglide and custom converter. I'd like to get some peoples opinions on my build and hear about your builds as well. Trying to build this thing as cheap as I can but I do know its still gonna cost me quite a bit. Thanks in advance for your replies
Old Jul 1, 2011 | 02:58 PM
kmracer's Avatar
search. theres threads about this all the time. you'll run out of turbo quicker than you'll have to worry about the bottom end.. you cant go wrong with a custom cam. you may want to go with the 1.10 A/R, even with e85.
have fun and dont be afraid to ask questions...
Old Jul 1, 2011 | 09:47 PM
YouGotJunk's Avatar
Anyone else got any advice?? Opinions??
Old Jul 1, 2011 | 10:01 PM
YouGotJunk's Avatar
Thanks for your response. I've searched a ton!!! There's a lot of knowledge on here. I was just wanting opinions on my personal combo.
Old Jul 1, 2011 | 10:11 PM
lsxmalibu's Avatar
Look for the parish fairmont threads, good stuff
Old Jul 1, 2011 | 11:29 PM
kmracer's Avatar
what are your particular goals with this combo?
Old Jul 2, 2011 | 12:27 AM
72montecarlo's Avatar
Parish is probably most famous have no idea If his fairmonts still goin tho was very impressive
Old Jul 2, 2011 | 03:11 AM
YouGotJunk's Avatar
Just wanting to run in a limited 8.5 class that's local. Trying to make 800rwhp. Gotta weigh 3350 with my setup. I'd like to be able to turn it up to possibly 1000rwhp and run some outlaw 8.5 just to have fun.
Old Jul 2, 2011 | 04:35 PM
kmracer's Avatar
you're definitly gonna want more turbo, and probably more cubes. are you running a standalone pcm? what are you doing for boost control? the s475 is likely going to be the limiting factor in this build.
Old Jul 2, 2011 | 06:15 PM
Speedy911's Avatar
I'm currently doing a build with a 4.8(was told it was a 5.3 but I checked it) and I have a Borg Warner S475 with a .90 T4 housing. I will also be using E85
600+ whp or go home.
9.50s or 140+ in the 1/4
