Signs of a bad Procharger?
Old 07-10-2011, 08:56 PM
AFASTYZFR1's Avatar
Originally Posted by MadIceV8
7.25" Crank/3.4" Blower spinning at 6,000rpm. Making 5-6psi. 8-Rib SDCE. SDCE is installed correct, belt is nice and tight. I upgraded to SDCE to rule out belt slip since I used to run the 6-Rib 6" crank/3.1" blower combination and only made 3.3psi.
What size cam? I make 14-16psi with that same pulley combo so something is way off.
Is the motor healthy? (compression and leak down test)
If the blower is correct rotation and is spinning freely and impeller is ok I don't see how that could be the problem.
Have you boost leak tested it?
Old 07-10-2011, 08:59 PM
Customizing Director
MadIceV8's Avatar
Bob@BruteSpeed - I didn't think the stand bypass valve or the Pro-Flo bypass have to be in a certain direction? Even so, I tried swapping the direction in the past. Haven't run the car with the BPV removed and the port blocked just yet.
blue00ZZleeper - I agree. I have a dyno sheet from when I ran a 6-Rib setup and made 3.3psi. I'll attach that later. I believe at 3,000rpm I am still at 10 vacuum.
AFASTYZFR1 - Stock camshaft. Motor appears to be healthy but I haven't done a leak down yet. FLP didn't think it will hold that much vacuum if the motor had something wrong. I may have to take a video of the P1SC-1 since I do not have anything else to compare it to. It takes a little bit of force to spin it but otherwise it is smooth.
Old 07-10-2011, 09:11 PM
blue00ZZleeper's Avatar
Even at WOT? Something is wrong lol. I would start with a compression test since its easy and then try a leak down if that shows nothing. Try what Bob said just to see what it does. That high of a vacuum is showing that you don't have that big of a leak. I run 20-30" running a gear out from a hard pull to slow down...not at idle or cruising. Also as asked a cam's spec's deff come into play with boost. Mine on a 370ci is a 235/243 115lsa and I see 10-12" at idle. 15" cruising.
Old 07-11-2011, 06:51 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
The inlet side of the ProFlow surge valve has the head of the bolt in the center of the butterfly being visible. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 07-11-2011, 07:46 AM
AFASTYZFR1's Avatar
I would check the motor out first just to eliminate that.
How does the car feel in boost? Any sputtering / lack of power ect?
What plugs are you running?
Old 07-12-2011, 07:53 PM
MadIceV8's Avatar
blue00ZZleeper - All numbers are at WOT runs I do on the street. They may be off ~1 psi since I do have to look at the road . 3-4psi with the 3.85" pulley and 5-6psi with the 3.4" pulley, both on SDCE 7.25" crank spun to 6000rpm. I hope to do a leak down test this weekend if I have time. Not sure what you mean by "20-30" running a gear out"? My camshaft is currently stock as I wanted to get numbers 1st prior to a cam install.
Bob@BruteSpeed - Thanks, I didn't expect that to make a difference. I will still try a run with the BPV removed and the outlet capped prior to any other tests.
AFASTYZFR1 - The car does have more power, but remember it is seeing boost, just not the amount it should be at. I am running NGK TR-6's gapped to I believe .30.
**I attached my initial dyno sheet from FLP. This was right after I first installed the Procharger with a 6-rib setup. So the crank pulley was only a 6" with a 3.0" blower. At the time I only saw 3psi... on the dyno gauge is read 3.3psi.
Old 07-13-2011, 12:11 PM
I mean I only see that much vacuum if I do a full pull and stay in gear to slow down with 0 throttle. I'll keep brain storming and try to think of anything else. I would still say try the leak down and compression tests to rule out the motor first. Hope all goes well man! Keep us updated.
Old 07-19-2011, 08:38 PM
383camaroz28's Avatar
View My Video
Does this sound normal? Few kids near me say it sounds bad
Old 07-19-2011, 09:44 PM
AFASTYZFR1's Avatar
Originally Posted by 383camaroz28
View My Video
Sounds fine....that's what a centrifugal blower sounds like.
Did the op ever compression/leak down motor?
Old 07-19-2011, 10:09 PM
Sorry not to hijack, they think its bad because its a d1 that sou.ds like a f1
Old 07-20-2011, 04:53 PM
MadIceV8's Avatar
I've been swamped over the past week, so it's just been sitting in the garage. Hopefully this weekend.
Old 07-21-2011, 12:48 PM
  #32
WHPLASH's Avatar
I don't want to highjack this thread, but....
I had my car dyno tuned last week. The car was seeing close to 14 lbs of boost. The last pull, it went down to 5-6 lbs. I thought it was a hose, but I've checked everything and its all tight and on. I need to look at it a little better, but I lost 8 lbs somewhere.
Old 07-21-2011, 04:04 PM
  #33
AFASTYZFR1's Avatar
Belt slip
Old 07-22-2011, 06:54 AM
  #34
WHPLASH's Avatar
Belt slip
SDCE setup and tight as a banjo!!!
Old 07-22-2011, 07:06 AM
  #35
LS1Tech Sponsor
Question
Cracked intake manifold? Bob
__________________
Old 07-22-2011, 07:18 AM
  #36
WHPLASH's Avatar
We'll find out tomorrow when I tear it all apart. It drives and idles fine. No issues other than missing 8 lbs of boost.
I was thinking a cracked plenum, but there's nothing noticable from a top visual.
Old 07-22-2011, 07:41 AM
  #37
LS1Tech Sponsor
Cap the tubing at the blower and the throttle body, then put a schrader valve in one cap and add some pressure to it. Bob
__________________
Old 07-22-2011, 07:59 AM
  #38
WHPLASH's Avatar
I can see capping the tubing before the t/b, but where exactly near the blower? You have the inlet hat and the filter.
Old 07-22-2011, 08:06 AM
  #39
LS1Tech Sponsor
Where the pressurized tube comes off the outside side of the ProCharger head unit. Bob
__________________
Old 07-22-2011, 08:11 AM
  #40
WHPLASH's Avatar
Thanks. I'll figure that out.
Quick Reply: Signs of a bad Procharger?
