AES 410c.i. LSX & KY-Turbo
Well I just got back from KY-Turbo! I took my car and all my parts to Josh so he could get started on installing things. Motor is to be deliverd to him. Josh is one of the coolest ppl you will ever meet or do business with. I cant wait for the first time hearing it and all the finshed work. This has been a long time a coming for me.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
Josh may modify them to work with the rockers or may go with an entirely different set of valve covers all together. He will have to check it out to see what he can or can not do. Clearance might be an issue with the heater box. Where I am going to be keeping the AC.
#40
Well guys my engine is on its way to Josh@KY-Turbo. Shipped out this morning. So he should receive it by Wednesday. He will be changing the heads to the Trick Flow 245 6 bolt heads! I think they should do the build better than the AFR 225's. I will be going with the the Moser 9" rear end and Wilwood breaks front and back. QA1 shocks.
