MAP Sensor advice needed.
Old Jul 13, 2011 | 12:23 PM
vxr8uk's Avatar
Default MAP Sensor advice needed.
Hi
My car is fitted with a Maggie 2300 supercharger kit which reuses the std OEM MAP sensor I would like to replace it with a 1.5 or 2 bar sensor.
I only 2bar Sensor number I have tracked down is 12615136 is a wrong shape and has plug in the wrong location.
Does anyone know which 1.5 or 2 bar sensors will fit onto the Maggie in place of the current 1 Bar GM sensor (part no 16212460) that is currently installed.
Thanks In Advance
Old Jul 13, 2011 | 02:04 PM
Sweet_SS's Avatar
http://www.tunedbyfrost.com/products_sens01.htm
Old Jul 13, 2011 | 05:12 PM
vxr8uk's Avatar
Originally Posted by Sweet_SS
Thanks - this looks like it will fit
Do you know where i can find a data sheet for this device?
I will need to change the Map Entries in the tune file so will need to the enter in place the stock 1bar settings in the following PIDS.
{B2101} MAP Sensor Scaler
{B2103} MAP Sensor Offset
{B2104} MAP Default for Throttle DTC
{B2105} MAP Sample Rate
Old Jul 13, 2011 | 05:25 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
FYI, you need to flash a 2-bar operating system in as well to be able to use the 2-bar map sensor.
Old Jul 13, 2011 | 05:28 PM
Sweet_SS's Avatar
I wouldn't know man. I have HP Tuners...all that is already figured when I switched to the 2 bar OS
