KY-Turbo Build
Old Sep 13, 2011 | 10:51 AM
  #41
273sunsetZ's Avatar
Update:
goal was to get the car to lsfest and run a 9.99
2nd pass it went a 10.07 @ 135mph 1/4 6.5 @ 111mph 1/8
The thing freakn moooooves out on 11psi, put it on the dyno while we were there and it made 614 hp 530tq @ 6200 where he let off, this is @ low 10's afr, we leaned it out and thats when it trapped 135, first pass was 130mph.
Would have ran it more but kept blowing oil out of random seals due to crank pressure, we finally vented the valve covers with hoses running to beer cans/atmosphere, and it didn't blow out nearly as much but still some, need to find out where its coming from and i'll be back.
enjoy
http://www.youtube.com/watch?v=ORCMc4cXq1E
_
PSSSSSSSSSSSSHHHHHHHHHHHHHHHHHHHHHHHH
Old Sep 13, 2011 | 10:55 AM
  #42
Sweet_SS's Avatar
Good job. But if I can say, you really should cut out your bumper for that FMIC. I bet you'll make a little more power...cooler IAT temps.
Old Sep 13, 2011 | 11:23 AM
  #43
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yep the car was pretty stealthy at LS Fest.
When's a stouter rearend going in?
I forget, are you running a TH400?
Old Sep 13, 2011 | 11:34 AM
  #44
lemons12's Avatar
I know its a built 3sp, its been in over a year iirc.
Old Sep 13, 2011 | 12:27 PM
  #45
willizm's Avatar
What is your weight with you in it?
Old Sep 13, 2011 | 02:58 PM
  #46
ls1curt's Avatar
nice passes, get them 60's down and up the boost
Old Sep 13, 2011 | 03:44 PM
  #47
273sunsetZ's Avatar
Pro stock its a th350 with a jw housing. Stock rear end is making some noise but I'm confident its in the brake pads sounds like somethings rubbing.
With me in it, car weighed 3515. Its a no option hard top car, they tend to be a bit lighter
Old Sep 13, 2011 | 11:23 PM
  #48
ZTwentyAteU's Avatar
That pass was a 9 sec run justin, you didnt even make it to the mph traps before you let off!
What about goin thru tech..."whats it gona run?" -"maybe 12.0s" hahaha
Old Sep 14, 2011 | 11:36 AM
  #49
273sunsetZ's Avatar
I KNOW! I wish i would have just bought 85lb injectors and been done with it.
I was sweating during tech cause i went up when all the radial cars were there, and I was watching how close they were checking everything, especially the helmet. I pulled up and thats all he asked, didn't even get to pop the hood or get to show him my dirtbike helmet haha
