TC78 owners come in!
Old 07-26-2011, 02:17 PM
  #41
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by djfury05
Looks good I like shiny! ^^ I sent you (Dr. Turbo) a PM on July 19th.. dunno if you got it? It was about the ST80.
PM replied
Old 07-26-2011, 02:18 PM
  #42
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by HydroStream6
If you want to take the drive to Rochester, you're welcome to check out my front mount with the PT7875. It's easier to get an idea when you can see it.
I ran the TC76 for 3 years and now the 7875. The TC was a good unit, I really don't have any complaints about it. It served me very well. The Precision however spools almost as fast and carries a lot more up top, especially once you get over ~15 psi.
The TC is a good deal smaller though. I had to do a little work to get the 7875 in it's place.
This new TC7876 should help solve the issue of space constraints and still have the top end you guys are looking for.
Old 07-26-2011, 02:19 PM
  #43
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by DrTurbo
You guys with the TC units we will probably have some upgrades. We are working on it. Also the GTM76S and GTM78S will be quite a piece
For those asking in PM's.....yes the units will be available in the 1.15A/R housing and the big turbine wheel also.
Old 07-26-2011, 02:42 PM
  #44
headed-ws6's Avatar
What do you think the new tc unit will be rated for as far as hp?
Old 07-26-2011, 03:16 PM
  #45
jt76's Avatar
another random queestion (without starting a new thread)...
Will a JGS 40mm WG be able to keep a PT76GTS in check? My friend ran a 38mm tial and a 76gts on his old hi-flow kit and it was fine.
EDIT: also, what is the power potential limit on a set of 317 heads?
thanks
Old 07-26-2011, 03:54 PM
  #46
MUSTANGBRKR02's Avatar
76GTS should have a 50MM wastegate or so.
317's are anywhere from 500-1000 RWHP.
  #47
headed-ws6's Avatar
If you can swing it id go with a 44mm for room to grow, and most people just put dual valve springs on the 317's and go. From what I've read people have pushed stock 317's to the limit to where they lift due to the thinner deck on the head's. Id say 800rwhp would be pushing a 317.
Old 07-26-2011, 06:53 PM
  #48
ablakez28's Avatar
Wastegate priority is going to have a large factor in what size will work for you. That said I would still get the biggest/best budget will allow.
Old 07-26-2011, 07:53 PM
  #49
Fbodyjunkie06's Avatar
PT76GTS FTW!
Really though this turbo hits really hard and pulls like a sombitch up top.
There is a guy on here with a 365 LS2 and a PTE76GTS on the corn making 830rwhp and 880rwtq on a 224/224 114 cam and 317 heads IIRC.
Old 07-26-2011, 08:19 PM
  #50
jt76's Avatar
The price of a Tial 44 really isnt going to kill me in the grand scheme of things lol.. The issue i have is the kit is built with the smaller WG so i would probably have to modify the pipe going to the WG as it is tucked pretty close and from what i remember the tial 44 is pretty bulky.
Old 07-27-2011, 02:12 AM
  #51
ablakez28's Avatar
The new Tial MVS/R gates are much smaller then the ones they replaced. You would be looking at the MV-R which replaced the 44.
Do you have a pic of how the wg is integrated into the kit. That will tell a lot.
Old 07-27-2011, 06:46 AM
  #52
jt76's Avatar
I believe the MVS is the same width as an old 44 but quite a bit shorter. I will snap a pic when i get home from work but i think it will have to be modified (i would have to cut the flange off for the v band anyway so i guess its not a huge pain)
Old 07-27-2011, 12:13 PM
  #53
ablakez28's Avatar
I can modify/weld it for ya if you need. You can bring it over and size it up to one of my MVS gates if you want. Dan Lesser has a few MVRs that I am sure we could use for test fit/ideas as well.
Old 07-27-2011, 02:12 PM
  #54
jt76's Avatar
Cool drew, thanks!
I made a deal witha guy last night for brand new PT76GTS, sending the money out friday. Billy turbo got by with the same turbo and a 38mm wg, but the general consensus on here is a tial44 or larger equiv.
Old 07-27-2011, 03:10 PM
  #55
Nitroused383's Avatar
I had the TC76 on my turbosmart 38mm wastegate with a 7lb spring. It would control to 7lbs unless it was cold in 4th gear it would hit 10lbs. I swapped a PT76GTS in place and with my cutout open it hits 15-16lbs of boost in 3rd gear. You will not want a 38mm gate with the precision unit, it will not control it on a 346.
Old 07-29-2011, 01:41 AM
  #56
Vetal's Avatar
We answered it long ago my friend. Sent 2 more blankets with USPS tracking to the same address and still they magically come up missing??
I've never received neither blankets nor even these tracking numbers, can you provide any proof of your words? You PROMISED multiple times to send and every time there was some excuse and then you just stopped responding to my messages. Apparently you didn't send anything or you wouldn't have reason not to answer my messages.
Old 11-28-2011, 04:52 PM
  #57
gimmeluvin's Avatar
update on the TC7876???
Old 11-28-2011, 06:01 PM
  #58
BLINGOLE's Avatar
Dude, months. Call turbonectics and ask. I've been waitin since july. At first it was the fall, then dec, now its a few more months away.
Old 11-29-2011, 11:35 AM
  #59
ZL1Killa's Avatar
made 650hp 680tq on TC76 with 13 LBs and ls1 w/ls6 heads. bore was 3.905
6 speed manual
Old 11-29-2011, 11:52 AM
  #60
LS1TECH Sponsor
DrTurbo's Avatar
Test unit is done my friend. Testing and dyno charts will be coming soon.
Stay tuned.
Quick Reply: TC78 owners come in!
