wrapping exhaust pipe wet?
Old Jul 22, 2011 | 10:31 AM
ToxicWS6's Avatar
Default wrapping exhaust pipe wet?
lookin at wrapping my headers back with exhaust wrap and some one mentioned letting it soak in water before i do it then wrap it tight and clamp it when im done then start car and let it get hot and dry up and when it does it will shrink and tighten up more and when dry spray with sealant or somethin, but i also read how moisture can get in it and cause the pipes to rust and all, so soaking it sounds like a bad idea if it will hold the moisture, any one have any suggestions on this? thanks
Old Jul 22, 2011 | 10:37 AM
vandal0-0's Avatar
Thats how I did mine when I did it and never had a problem.
tim99ws6's Avatar
unless it's the new lava wrap stuff, soak it.
even then, I'd probably still soak it.
Old Jul 22, 2011 | 11:05 AM
91blowthru's Avatar
I prefer the regular wrap soaked, not lava wrap. If theure off the car, let em sit in the sun, when it dries it shrinks up nice and tight.
Old Jul 22, 2011 | 11:28 AM
NEVERTWOFAST's Avatar
I first painted my crossover pipe with heat paint than I soaked and wrapped mine, let it dry in the sun and painted it again with heat paint. Still looks great.
Old Jul 22, 2011 | 12:08 PM
Need_a_Camaro's Avatar
That's how I've always used the stuff. It helps it fit better, and keeps the fiberglass dust down a lot. Your nose and lungs will thank you.
Old Jul 22, 2011 | 12:19 PM
HydroStream6's Avatar
I ceramic coated my pipes, then soaked the wrap and wrapped. Used hose clamps at the ends. Put them in the sun for a couple hours, then painted with that silicon stuff. 2 years, so far so good.
Old Jul 22, 2011 | 01:23 PM
01Z28Camaro's Avatar
I wrapped mine while wet, then sprayed with the hi temp silicone paint. Been a couple weeks now. The paint hasn't went away or faded, My manifolds were bare and rusty looking an I did 3 coats of the silicone paint and they look good now.
Old Jul 22, 2011 | 01:58 PM
ToxicWS6's Avatar
ight cool, sounds like what ill do then! Thanks guys!
Old Jul 22, 2011 | 02:51 PM
6techniques's Avatar
my pipes are wrapped with a coating of hi-temp paint underneath...I let it sit in the sun as well and it dried up nice and snug...just the way I like it!
Old Mar 13, 2013 | 10:45 PM
JoshuaGrooms83's Avatar
ok so just to get it straight
-VHT high temp paint the exhaust
-soak fiberglass in water
-wrap exhaust
-spay wrap again with????
- run car for 10-15 minutes then shut off for a cycle of 3 times then drive the car
about right?
Old Mar 14, 2013 | 06:30 AM
Taubr Unit's Avatar
What if u have a car that doesn't run like mine, lol. I have the lava wrap so if I soak that and put it in the sun or inside my house will that work?
Old Mar 14, 2013 | 07:21 AM
9sectruck's Avatar
I didnt soak mine and I itched for two days, that **** will not come out of your pours,
mine seems to be holding up good (keeping tight wise)
Old Mar 14, 2013 | 07:50 AM
quicksilverado's Avatar
Use gloves when wrapping dry or wet. It will save you a lot of skin irritation.
Old Mar 14, 2013 | 12:33 PM
OldGold's Avatar
Hmmm, I did not soak mine, or even think to soak it. I wonder if spraying it at this point would have any impact on the tightness? Mine is tight, for the record.
Mike
Old Mar 14, 2013 | 12:52 PM
FASTFB's Avatar
I used lava wrap. I first painted my crossover with high temp bbq paint think it was 1500 degree paint. I then dipped the lava wrap in a big bowl of water as I was wrapping the exhaust. It really helped as you can really stretch the wrap while putting it on. I let it dry over night, then painted the whole thing with dei silicone spray. It work very good and looks nice also. Wear some rubber gloves while you wrap it. I put a sweat shirt on and rubber gloves then taped my sleeves over the gloves haha. I didnt itch at all.
Old Mar 14, 2013 | 01:05 PM
98Z28CobraKiller's Avatar
Restricted User
-wrap exhaust
about right?
That's how I did it. If you want to **** off the wife, after you spray them initially, throw them in the oven at 500* for 30 min before you wrap them.
Old Mar 14, 2013 | 01:29 PM
willizm's Avatar
I wrapped mine dry and it was easy since I had them swaintech coated which has a rough grip to it.
Old Mar 14, 2013 | 06:38 PM
evo462's Avatar
What about the DEI "Titanium" type wrap? Is that similar to the lava stuff mentioned?
Old Mar 14, 2013 | 06:54 PM
i just wrapped mine. VHT black painted the Ipipe since it was kinda rusty but left the headers and ypipe alone since it was wtill shiney lol but I soaked it and wrapped it on the car... byt he way that sucked doing it on the ground lol but i did pretty well considering it was my first time lol
