Anybody with stock cubes & T6 78-85mm turbo I have ???s
I bought an OFI kit which was listed as a T4 kit, but is actually a T6 kit. I had a PT76 I was going to use with it, but unless I wanna build a new x-over & DP, I'm going to need a T6 snail with a 5" DP. I figure the kit was probably built for a S85 or bigger. I was thinking about an S400-78 or 80 being I have a 347. Anybody running any T6 turbos on a stock cubed motor with good spool time? Anybody have any better ideas?
What rpm did you start to make boost? and what rpm did it make full boost?
Are you using a quick spool valve?
Bozz
