*Dyno runs*... 454LSX,TFS245, Twin billet wheel 67's
#41
Wow that’s wild
I have just organised a pair of TFS 245cc 6 bolt heads for my LSX 427 build and I was hoping these cathedral port heads would work well with boost and this has answered my question. Good to see that the TFS heads can still perform just as well as any of the LS3 heads available, both boosted and N/A.
Finally got some dyno numbers on it. 1100rw and 1165tq...15psi. Ended up going to 220lb injectors and twin weldon pumps. E85 takes a ton of fuel system to make this power..but its working out really nice. Should have some higher boost numbers pretty soon...
btw, intercooler worked better than expected. 60-65 degrees inside the shop today, and intake temps at peak power are 77 degrees.
#49
#50
FYI the Supra was on 27lbs that night with 3 cracks in the intercooler, you left on the second honk and i still came around you. Not once but 3 separate times if I recall correctly. There was never an even hit and you got out gunned. If you beat my Supra then why did you pull back into the meet get out of your car walk up to me and shake my hand saying "congrats on the win, we're gonna figure out whats wrong and turn it up" Lots of people saw you do that.
BTW new combo on this thing is stupid clean and should be ***** fast! Not trying to down it or you just stating the Supra side of the story.
#52
He never said he BEAT you he said "putting 1/2 a car on him". I hope you would come around him considering you make alot more than he did at the time.
#54
regardless, both guys drive potential 1500+HP cars. and i will drag both from a 60
#55
lol 3 wide, you're both screwed. Or man up and meet me at the track
#56
#60
