5.3 turbo keep stock 5.3 heads or use my ported ls6?
#41
again, you can sit here and use math and theory, but that isnt always practical. the example you provided hardly backs up your point, seeing as the made double the power the OP has in mind with "stage 1" (whatever that means) stock heads....
The example does back up what I was talking about. If you dont understand the post the example may not seam to back it up. If you do understand then it becomes clear and is backed up.
If you dont understand or believe what is posted above then I recommend either moving on or digging deeper by researching on your own.
#42
Ok guys I have a few questions, I'm new to fi I'm ordering a single turbo kit for a 2000 5.3 I've heard that a stock ls1 cam will work or a ls6 zo6 cam, can anyone tell me if that's true or if I can get by with using all my stock parts for now and just upgrade injections and have it tuned after instal? Any help would be over much appreciated
