What heads and headunit question
Old Jul 28, 2011 | 10:59 PM
My6speedZ's Avatar
Default What heads and headunit question
Been kicking around the idea of maybe rebuilding my blown 347 and going with a procharger.
Here is what i have
TFS 215's, VRD ported fast 102/102, 1-7/8 headers, tru duals, and a un-wired 255 in the tank.
Bob said i could drop the FAST fuel pump that comes in his kit in-line to my intank pump and be good for 700rwhp. With the 60 lb'r of course.
I would be running his blower cam if i did this.
My question is this... should i rebuild the 347 and go with a d1
OR
go iron 370 with f1a
I know my fuel system is going to limit both set-ups to around the same power level.
But my biggest worry would be the size of my cylinder heads on the 370.
Old Jul 28, 2011 | 11:07 PM
yelo04goat's Avatar
im a fan of using what you got... its usually cheaper... why not just build the 347 and put the f1 on it?
Old Jul 28, 2011 | 11:11 PM
My6speedZ's Avatar
Didn't know if that was an option.
are there any 347's running the f1a's
Old Jul 28, 2011 | 11:16 PM
djfury05's Avatar
You'll be fine with the 347.. personally I like the weight savings with aluminum over iron too so when I am ready to build a motor it will be an LS2/3 block depending. I'm pretty sure I've seen a 347 w/ F1A and it was pretty sick.
Old Jul 29, 2011 | 02:03 AM
My6speedZ's Avatar
But if i did put the f1 on the 347 would the 215's be holding it back alot?
Old Jul 29, 2011 | 02:20 AM
djfury05's Avatar
No I don't think so.. what is your idea of being held back a lot? I am sure you could trade those out though if you really wanted to. Or get them ported is another idea.
Old Jul 29, 2011 | 11:56 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
KP got into the 8.80 range with his 347 and an F-1A with our blower camshaft. This was with AFR 225 heads. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 29, 2011 | 01:42 PM
My6speedZ's Avatar
I can have them ported by AI since they are local if i needed to. Perhapse on the next go around, when i step up the fuel system i could upgrade the heads as well.
Bob is there going to be any differences in power delivery or drivablity with 6-speed 347 with a d1 vs a f1?
Old Jul 29, 2011 | 03:12 PM
LS1Tech Sponsor
No, not really. The F-1A is going to be quite a bit louder, but it generally is music to most peoples ears. Bob
__________________
Old Jul 29, 2011 | 03:52 PM
never2low's Avatar
Im putting together an f-1a on my forged 347 with Bobs FI cam and some AFR 230 heads.
Old Jul 29, 2011 | 04:21 PM
98BLOWNZ28's Avatar
Reguardless of the motor you run, you should get an F-1.
Old Jul 29, 2011 | 07:03 PM
yelo04goat's Avatar
^^ that way when the motor goes you already have the blower.. no need to change it out
Old Jul 29, 2011 | 09:56 PM
djfury05's Avatar
I plan to run some Trickflow 220cc as cast heads that I will be getting them to CNC for me. I run their 243s now and love them! Great guys! F1A ftw.
