I have a sneaky idea on how to have a T6 AND a T4 turbo mount on the same crossover!
So i ordered at GT91 from forced inductions, with the optional t4 housing for the street. I would like to put the t6 housing on for the track and i was searching for a way to be able to interchange them easily. I came up with this:
make the crossover with a T6 flange, and use an adapter like this *nonsponser link removed* to reduce it to a T4. then i can run the T4 and easily remove the t4 housing and the adapter, and put on the T6.
seem like a good idea, or no? ive never seen anyone do this.
Hmmm, sounds like a novel idea, but I bet after doing it once or twice you will be so tired of doing it and you will find that spool time won't change THAT much with either. I don't see it being a difference of more than 4-500rpm.
Honestly on that T4 flange that turbo should be a monster and plenty enough. MM has gone 8.59 at 161 with his GT91mm T4 flanged turbo. I don't think you will need the T6 to meet your goals whatever they may be...
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
