Any turbo'd stock 5.3l mpg results available ?
Old 08-02-2011, 07:21 PM
Nic Morales's Avatar
Default Any turbo'd stock 5.3l mpg results available ?
First let me say Hi and my body hurts from looking thru this kick A@$ forum for the past few hours. I just joined Today !
I just acquired an 88 monte carlo " To be my wifes DD " and I'm looking to do a stock 99' model 5.3l with a single or twin turbo set up, with the stock truck intake. I would like to see if there are any mpg results from people with this type of set up. It's a 3200lb car with a 2004r trans and I think a 3.73 gear "tbd soon" With a 26" tire. Any mpg numbers from a 5.3l carb'd or FI numbers are of intrest to me. I cant wait to hear some numbers.. Thanks ....
The following users liked this post:
Dopeydinerdog (12-29-2022)
Old 08-02-2011, 08:27 PM
quicksilverado's Avatar
When I had a stock 5.3 and turbo on the truck I would get 22 mpg running 80-85 mph on the hwy. In town it would get right around 18 mpg. that was in a 5000 lb truck.
Old 08-02-2011, 09:10 PM
lsxmalibu's Avatar
I can manage 18 plus on the highway. Th350 3.42 gears. 26.5" tire. Stock 5.3 with z06 cam. Truck intake and fi
Old 08-02-2011, 11:34 PM
postal14's Avatar
LS motor + turbo for a daily driver for the wife. You better get a car with air bags or leave off the turbo if she drives like my wife.
HTH
Old 08-02-2011, 11:51 PM
01Z28Camaro's Avatar
Just for the perspective, I get 22 mpg highway with H/C/I 370 with pt88 turbo going through a th400, steel driveshaft and 12 bolt with tru trac.
Old 08-03-2011, 12:17 AM
skinnies's Avatar
22mpg on my rx7, 18mpg in my ltd, both with th400's and both on e85.
Old 08-03-2011, 12:25 AM
code4's Avatar
I get 20 on the hwy if I don't play too much. It's a 54 chev p/u 4l80, forged, 317's zo6 cam, single turbo
Old 08-03-2011, 01:59 AM
Fbodyjunkie06's Avatar
How fast are you driving to get those numbers? You have 3.08's and 28" tires too right?
Old 08-03-2011, 02:43 AM
Got those numbers when I drove from St Louis to Kansas City to race. Was on 25.7 inch Nittos with 3.42 gears going 55 mph at 2600 rpms. Now does 65 mph at 2600 rpms.
Old 08-03-2011, 03:18 AM
SB2NOVA's Avatar
What kind of power numbers are you guys getting with 20 mpg. I was hoping to get somewhere in the 600+ range and would be really happy with 15 mpg. to be honest. Doing a 5.3 with a single 88 with a cam upgrade.
Old 08-03-2011, 05:22 AM
skinnies's Avatar
686rwhp on the rx7, the ltd should be over 800rwhp just haven't dyno'd it
Old 08-03-2011, 03:52 PM
HTH
Yes I do have my fears. I will probally keep the rev limiter @ 4000 when she drives it...And always on the drag radials..lol
Old 08-03-2011, 03:59 PM
Default Thank You !
Thanks for all the replies guys. I'm sure I'll be on here alot picking brains on this project. I got to remove 4 broken manifold bolts from the heads and then I'll be shooting to collect the parts to fit this "junk motor " down in the car..Thanks again..
Old 03-29-2022, 04:06 PM
97sierrarcsb's Avatar
Default Gas mileage
what size was the turbo, want this gas mileage on my 97 sierra, thx
Old 04-01-2022, 06:12 PM
customblackbird's Avatar
I get 20-23mpg highway in my 87 TA which has a cammed 5.3, single turbo, 2004R trans from a Monte Carlo (built it up with billet parts from CK performance) and a ford 8.8 with 3.55s. With a 28” drag radial and a billet 2400 stall 10.5” converter I cruise around 80mph and manage the 20-23mpg out of boost of course. I DD the car in the warm months and it’s better than my 18 Ram with the Hemi on the highway and way more fun to drive. Make sure you make all the mods to the 2004R so it survives and
Mine hasn’t skipped a beat up to 15psi or 700-750hp at the crank.
my converter is a lockup of course and at 80 I’m doing like 2200rpms.
your out of boost when your cruising so the mpg comes down to the NA 5.3 fuel usage and the gearing or what RPM your at at what speed abs what TPS. In boost your going to get like 15 or less if you like to make boost around town. But that’s the beauty of a turbo LS, reliable easy HP for fun and good MPG if you keep your foot out of it and out of boost. Which if the turbo is sized right would be less than 30% throttle and below 2500-3k in cruising but on light throttle.
The BallSS (04-04-2022)
Old 04-04-2022, 04:14 PM
The BallSS's Avatar
I was going to suggest to the OP going to a 3.42 rear gear and a 28" tire and judging by what your saying sounds perfect.
Old 04-04-2022, 05:39 PM
RonSSNova's Avatar
This post is from 2011.
Old 04-04-2022, 08:55 PM
Bad Apache's Avatar
Like "The Fast and the Furious".... just keeps coming back.
The following 2 users liked this post by Bad Apache:
Dopeydinerdog (12-29-2022), freeky (04-05-2022)
Old 04-05-2022, 10:18 AM
The BallSS's Avatar
Uh ****.
Old 04-05-2022, 09:27 PM
Bad Apache's Avatar
No worries. It's an interesting thread. Especially for us daily driver types.
Quick Reply: Any turbo'd stock 5.3l mpg results available ?
