Seat pressure with XER cam with boost at 20+ pounds?
#41
Those trickflow heads have farily heavy valves. A popular mod is to use turned down LS3 hollow stem valves. TEA does this and Chris1313 has a post on here with back to back results on a N/A setup. Helped out quite a bit above 6500 rpm. There is not much out there that is a light as the stock rockers on the tip. Those rollers on the tip of aftermarket rockers are heavy.
#52
It seems now that all problems are solved, so certainly no extra spring pressure is needed.
Although I'd like to know which YT's were used, and why some experience problems and others dont ?
I'm using the YT Ultralights, 1.7 ratio, and mine spins freely to 7k no problem at all.
So is the problem only a rocker problem, or a combination of parts problem ?
#53
I was referring to the more seat pressure query. Although I picked it up that he/she was still experiencing problems which is why they wanted to know if more seat pressure would be needed.
Given that the XER lobes were never really meant for an LS anything and their ramp rates and it being in the high 23's low 24's in duration I can see how a heavy rocker especially one heavy on the tip where all the force of the wipe pattern is concentrated being the breaking point in this situation. Combined with the heavy trick flow valves it sealed the deal for valve float. Nitroused was having valve float in his ride not too long ago so I'm sure he exhausted all the options this route leads to before he got his diagnosed right.
Tracy what springs do you have in now?
#54
I tend tend to agree with your statement of 170 pounds of seat pressure being enough for a cam the size of his and the rpm range given. Valves and rockers do play their part in that equation too though as do the pushrods.
#55
Hey stevie, definately a he. No issues, i'm used to it by now, lol. I was using the YT ultralite's. I bought them about a year ago so it should be their newest version i would imagine.
hey junkie, i'm using the k800 k-motion springs w/titanium retainers. They are slightly larger at 1.46 OD so i'm sure that added a bit of weight as well. I think you're both correct.....it had to be a combo of parts to cause the float. I don't plan on using an aggressive lobe again for a street car!! Thanks guys, tracy
I see why so many people use the stock rockers with the comp trunion upgrade. I think I know what else to add to my list while the motor is out!
#57
It all has to with the weight of the valvetrain. LS6 and LS3 heads have some of the lightest valves available. If you do some searching you will find quite a few people with trickflow heads and aftermarket rockers who are down on power in the higher revs N/A. Here is a good thread from thunder racing https://ls1tech.com/forums/dynamomet...ts-inside.html
#58
I'm also using Trickflow heads with no issues.
I was led to believe the stock rocker setup would not work with their heads. Although Ive never had a stock setup to try anyway
#60
Hey beaflag, yes, i've already raised it a total of 10 pounds....68 base pressure. Since the new valve springs and more tuning, i have an injector duty cycle in the upper 80's with only 15.5 pounds of boost. If i want to crank up the boost another 5 - 10 pounds at the track, i think i'm going to have to go to a larger injector. I just don't know what size to get.....i don't want idle issues so i'm taking my time to get the right one. Any suggestions? Thanks
