Pushing water through copper HG
Old Aug 19, 2011 | 02:40 PM
408ant's Avatar
Default Yesterdays #'s
1.32-60ft
3.408-330ft
5.065-1/8
147.22 mph
6.545-1000 ft
7.775-1/4
183.56 mph
Old Aug 19, 2011 | 02:46 PM
Larry @ AMS's Avatar
Originally Posted by 408ant
1.32-60ft
3.408-330ft
5.065-1/8
147.22 mph
6.545-1000 ft
7.775-1/4
183.56 mph
congrats again! keep at it and you will go deep into the 7's
Old Aug 19, 2011 | 03:00 PM
87silverbullet's Avatar
Thats what I'm f&%$#^ing talkin bout! Did the heads stay down or is it still trying to push coolant. Did you mess with the tune any?
Old Aug 19, 2011 | 03:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Congrats on that 7.77 Anthony!!! I heard about it via the grapevine this morning.
Old Aug 20, 2011 | 09:53 AM
408ant's Avatar
Default Thx
Thanks Guys for all Your support, Heads stayed together so far. We did mess with the tune still pretty rich seems likt the more we clean it up the more power its making. Were gonna have about 2 more runs befroe its perfect. Then were gonna turn it way up. Got to be competitive for Holley fest. Only 25lbs of boost so far!!!
Old Aug 23, 2011 | 10:20 AM
Thats good to hear. Get that thing right and turn it up. I would like to see what it will do on higher boost.
Old Sep 5, 2011 | 09:04 PM
408ant's Avatar
Default Shitttt!!!
Well Here we go again. JUst Gettin the car readdy for Holley Fest and Pulled plugs. Once again there was water. Every cylinder on driver side had water on plug after sittin, and back 2 cylinders on pass side had wateron plugs. I don't know what the F is up?? Any suggestions NOW??
Old Sep 5, 2011 | 09:33 PM
You gonna have to pull those heads. Something is either wrong with the gaskets or the heads. Is the tune more to the aggressive side or is it still conservative? Where is your timing at? Do you have any of your last few runs datalogged?
madmax4499's Avatar
did i miss it? what did AES have to say?
Old Sep 5, 2011 | 10:15 PM
408ant's Avatar
timing at 17 degrees, air fuel at 11.1 to 11.3. I didn't tell them yet at AES. Yea we ahve them logged on BS3 and racepak
Old Sep 5, 2011 | 11:21 PM
rotary1307cc's Avatar
man thats gotta be frustrating
Old Sep 6, 2011 | 01:35 PM
  #32
LASTLS1's Avatar
6 Second Club Moderator
Nothing is wrong with the tune, it's soft.
Old Sep 6, 2011 | 04:20 PM
  #33
possessed1's Avatar
Well Here we go again. Just Getting the car ready for Holley Fest and Pulled plugs. Once again there was water. Every cylinder on driver side had water on plug after sitting, and back 2 cylinders on pass side had water on plugs. I don't know what the F is up?? Any suggestions NOW??
Ant , I told you why the gaskets are gone this time . Car blow the tires off about 60 -80 ft out and hit the rev limiter and went big bang out the exhaust .
We made 20 passes on those gaskets and we only had signs of water seepage. Now after we banged it off the rev limiter theres a **** ton of water in the holes .
Old Sep 7, 2011 | 09:54 AM
  #34
LS1Tech Co-Founder
Just have a smoke and then set the rev limiter at 10,000.
Old Sep 7, 2011 | 10:18 AM
  #35
98Z28CobraKiller's Avatar
Restricted User
That'll do it. Might want to move that limiter down a bit. I was also curious as to whether or not you are retorquing the heads with the copper gaskets? I've heard that is necessary after a full heat cycle, all be it a huge pain in the *** unless that heat cycle was on an engine dyno.
Steve's car has made many 7.8-8.0 passes on the Fel Pro Head Gaskets and no o-ring @ 3650 race weight.
Old Sep 7, 2011 | 11:08 AM
  #36
I have been hearing good things about the Fel-Pro MLS head gaskets. I know David Childress (Mightymouse) uses them also.
Old Sep 7, 2011 | 11:30 AM
  #37
LASTLS1's Avatar
IT's not the head gaskets, back fires, torque process, or any other silly thing. I have a feeling when the motor is torn down and speced out he'll find the problem. A LOT of people are makeing a ton of passes on the six bolt set up without blowing gaskets every 6-8 runs @ 25 lbs of boost! Somethings off with that motor. He blows more gasket than I did with my 408 iron block and that's saying something from the "blown head gasket director". LOL Somethings not right in the motor.
Old Sep 7, 2011 | 11:49 AM
  #38
jasond26's Avatar
What in the bottom end would cause headgaskets to push water? I would guess that maybe the deck on the heads is not true. Did they get decked after the first time he lifted the heads? I am just asking these questions out of curiousity, not to question your theory.
Old Sep 7, 2011 | 11:57 AM
  #39
possessed1's Avatar
Originally Posted by LASTLS1
It's not the head gaskets, back fires, torque process, or any other silly thing. I have a feeling when the motor is torn down and speced out he'll find the problem. A LOT of people are makeing a ton of passes on the six bolt set up without blowing gaskets every 6-8 runs @ 25 lbs of boost! Somethings off with that motor. He blows more gasket than I did with my 408 iron block and that's saying something from the "blown head gasket director". LOL Somethings not right in the motor.
Yeah theres something wrong in the motor all right Its called DETONATION !! Thats the only thing wrong with it !
And just for the record we had 20 passes on those gaskets with no problems , Until we banged it off the rev limiter .
Old Sep 7, 2011 | 12:02 PM
  #40
LASTLS1's Avatar
On inital check pistons were hitting the heads. That was repaired. I know the install on the o rings is critical! Not sure. Why is he the only guy blowing head gaskets like crazy on a LSX six bolt set up???? We run the same fuel, timing file, A/f ratio well he's a little richer than I am. I NEVER pushed one drop of water since I put the LSX in and I'm 200 lbs heavier and have been faster than him.
