1/8 results turbo lq4 PICS&VID!!
Went out last night and made a pass. Left on about 4Psi and 13-14 down the track and managed a 1.88 60" 7.40 @ 99
This is shifting at 6100 and AFR in the high 10's low 11's with a little heatsoak but nothing compared to last time. Next week I'll put some dope on it and leave out the gate with it and raise the shift points to 6300 and get the AFR's in the mid 11's.
I drove it to and from the track, A/C , power windows blah blah and I did not change tires or even tire pressure when I got there running stock 16's with 295/50 drag radial out back!
http://www.youtube.com/watch?v=Q3a5m...er_profilepage
ill be back with a little bit of nitrous out the hole and get a 6's with 100+ trap speeds
suspension just caltrac's and its lowered 4/5
it dead hooked out the hole its just not spooling fast enough but that should change next week. these tires work great i think i can get a 1.6 60' and break into the 6's with 102+ trap speed with this new tune.
Yea if your not spinning then it's just not enough power to move that pig outta the hole on 4 psi.
Transbrake or footbrake?
If you have a line-loc you can tie it into your footbrake or a momentary button and use it to build more boost at the line if you don't have a transbrake.
That's a big ol turbo too I'd say its for sure got a 102 trap in it.
im looking into a 2 step or just a 50 shot.
me and my tuner were talking about it and we are both thinking around 103-105 next time out without the nitrous. gonna ice down the charge pipe's and let her eat!!
