Does meth go bad?
Old Aug 18, 2011 | 07:22 AM
green95vert's Avatar
Default Does meth go bad?
Had a full tank in my car all winter long and whatever's passed of this summer. Should I empty the tank and refill it with new fresh stuff? Thanks!
Old Aug 18, 2011 | 07:38 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Is it 100% methanol? If so, then you're fine, it's not going to go bad. If it's a mixture, the issue could be that the methanol has evaporated, and now you have a lower concentration of methanol to water ratio in the tank.
Old Aug 18, 2011 | 12:35 PM
BadgeZ28's Avatar
It absorbs water from the atmosphere, so it delutes the purity if not sealed. Evaportation is the only other concern if kept in a container rated for it.
Old Aug 18, 2011 | 06:57 PM
stngtamr29's Avatar
+1 My dad used to own a 4 car sprintcar team and we would never use "last seasons meth" because it would draw so much moisture but you can usually tell if it has moisture in it because it will be cloudy. jeff
Old Aug 18, 2011 | 07:00 PM
Blownz28man's Avatar
Its hell on teeth
Old Aug 18, 2011 | 08:33 PM
UNDER PRESSURE MOD
Not true. Methanol readily mixes with water and won't get cloudy.
Old Aug 18, 2011 | 08:36 PM
stngtamr29's Avatar
Well maybe you should tell that to the 55 gals. of cloudy meth I have in my shop
Old Aug 18, 2011 | 08:50 PM
twinturbo496's Avatar
All meth is bad.
It makes your teeth fall out.
Don't do meth, even once.
Old Aug 18, 2011 | 09:11 PM
UNDER PRESSURE MOD
Okay, I'll toss my 20 years of chemistry experience out the window because you have a drum of cloudy methanol.
I'm not saying it didn't absorb moisture, because it most definitely will do that, but I'm just saying that being cloudy is a sign of other issues than just absorbing moisture. Most likely, air caused the inside of the drum to oxidize, and the methanol is cloudy because it's aerated. Purge it with nitrogen or helium, or a pull a slight vacum on it, and I'd bet it would clear up.
Old Aug 18, 2011 | 09:13 PM
stngtamr29's Avatar
Oh Im sorry I just noticed where your from you guys know it all, my bad
Old Aug 18, 2011 | 09:19 PM
UNDER PRESSURE MOD
I work with methanol every single day. I'm pretty familiar with it's chemical properties....sorry... I'll keep my skill set and experiences to myself.
My point is, just because you have cloudy methanol doesn't mean it's bad. But if you want to dump 55 gallons of it, by all means, do so.
You do realize that I'm a wet chemist right? I'm not just pulling this out of my ***. If there's anything I can bring to this forum, it's some chemistry knowledge.
Old Aug 18, 2011 | 10:50 PM
WhistlingZ's Avatar
Hahahahah
Old Aug 18, 2011 | 11:05 PM
CarsandWomen's Avatar
Old Aug 18, 2011 | 11:38 PM
Nemesis350's Avatar
kick his ***, sea bass!
Old Aug 18, 2011 | 11:43 PM
camarols1's Avatar
LOL !!!
I would listen to the chemist Mr.stangtamer, and tame down that defensive attitude.
The day a man thinks he knows all is the day he stops learning.....Just sayin...
The guy is trying to save you some money and possibly educate you with information that you may be unaware of, for free no less..... Yeah what a jerk, lol.....
Maybe you get methanol for free ????
I have spent less and less time on this site due to such disrespectful posts.
Lots of good info on here if you have the ability to sift through all the useless posts...
Back on topic,
Although I would not personally use the 6 month old Methanol as a primary fuel source, I wouldn't hesitate one bit using the same methanol as a charge air cooler, which is the OP's intention.
Even if it pulled in 5% water by volume, it will still serve the purpose in keeping IAT's down.
Jim
Old Aug 19, 2011 | 01:09 AM
Fbodyjunkie06's Avatar
lol isn't it called WATER/meth injection?
Old Aug 19, 2011 | 08:22 AM
Out it goes and new stuff goes in! Its the premixed stuff from Devil's Own. Believe its a 50:50 mix but I could be mistaken.
Old Aug 19, 2011 | 08:13 PM
no, some guys run pure methanol
Old Aug 20, 2011 | 07:06 AM
crashly's Avatar
yes, get rid of it..
Old Aug 20, 2011 | 07:08 AM
crashly's Avatar
you are correct
