Cheap supercharger kit: Part II
On the initial M90, a BOV was attempted before switching to an external bypass valve. The M122 had an internal bypass valve to regulate unneeded pressure. With the gift of experience, I'd suggest only using BOVs on undersized SC's, centrifugal blowers and turbos. Large PD blowers require a bypass valve of some sort
air filter - blower - BOV? - intercooler - TB - stock intake manifold.
On a typical PD blower, the TB is closed most of the time so only a minor amount of air seeps by. This creates a near vacuum behind the TB, so the blower has almost no air to compress, thus no noise. When winding out an engine, the TB is open, so the blower gets ample air to compress and thus the whine, but the engine RPM is also pretty high and changing so the sound changes as the blower goes in and out of efficiency range
With the side mount unit I built, the TB is downstream, so the blower perpetually has all the air it can use. The BPV kept the boost level manageable outside of spirited driving, but the blower was always compressing air. Since the air speed/boost was relatively static, the whine was also an ear splitting mono-tone
To counter that, the TB needed to be moved to the SC inlet. Simple to do, but the problem would become an absurd increase in plenum volume. The SC, all pipes, the IC and actual intake would be plenum volume and since the volume wasn't uniform, it was impossible to tune. Atleast the tuner I used couldn't get anything usable from it like that
I'm not sure what SC you're planning to use, but swap the BOV for a BPV and it should be viable
