many questions new to turbos
Old Sep 7, 2011 | 01:02 AM
LSjim's Avatar
Default many questions new to turbos
Ok so i am very intrested in trying out a turbo in my 2002 camaro i have ahad a turbo kit laying around for some time it has everything besides turbo wastegate and blow off but i was going to take out my ls1 and dump a 5.3 all stock besides doing arp rod bolts and arp head studs also some MLS gaskets but if i run a 76mm master power turbo what size wastegate? what size blow off? and also what do i need to do the oil lines? thnks sorry i am a newbie to turbos
Old Sep 7, 2011 | 08:19 AM
FastKat's Avatar
There is a lot of information already on this board. Start searching for the answers and you will find answers to your questions and questions you haven't even thought of yet!
Old Sep 7, 2011 | 09:29 PM
LSjim's Avatar
ill check around thnks
Old Sep 7, 2011 | 10:00 PM
71 chevy's Avatar
38mm wg
50mm bov
-4 feed line
-10 or -12 return line
Old Sep 7, 2011 | 10:33 PM
LSjim's Avatar
okay are thoes for the oil lines?
Old Sep 7, 2011 | 11:22 PM
71 chevy's Avatar
yes for the oil lines.
measure what length you need for the supply and get it from ebay, cheap- the braided stainless steel stuff.
for the return, i use push lok hose and cut it to length
Old Sep 7, 2011 | 11:28 PM
Fbodyjunkie06's Avatar
If you were able to swap the ls1 into your old v6 car a turbo kit will be no promlem for you.
Old Sep 8, 2011 | 01:14 PM
LSjim's Avatar
oh okay and yea i am alot better with just n/a build this will be my firts turbo install and i just wanted to besure everything is the right size for my turbo .. thnks 71 chevy
