journal or ball bearing
Old Sep 8, 2011 | 11:19 AM
Blown02Camaro's Avatar
Default journal or ball bearing
Im looking to buy a tc78 for my 383 stroker ls1. I need to decide if I want to add the ball bearing option or just keep the journal bearings. Is the ball bearing option worth the extra money?
Old Sep 8, 2011 | 11:47 AM
703 CAMAROSS's Avatar
I havent bought anything yet but i have been told you dont really need ball bearing with these v8's
Old Sep 8, 2011 | 01:30 PM
Kickergt's Avatar
Im partial to journal bearings. They are more street friendy. What i mean by that is they tend to last longer then the ball bearing units for daily driving. Thats just been my personal exp. But im sure there are people that have used ball bearing units on the street for a long amount of time without issue. I still went with journal
Old Sep 8, 2011 | 01:46 PM
stevieturbo's Avatar
For a big V8 where you wont be using high boost pressures, and spool time is much less of an issue, the use of ball bearings does become less of a need.
But for a small turbocharged powerful engine using a lot of boost...absolutely go ball bearing. Ive never heard of any reliability issues with quality units.
Old Sep 8, 2011 | 05:17 PM
so for 10-15 psi journal bearings should be fine
Old Sep 8, 2011 | 05:48 PM
Well I'm buying journal bearing and going to run close to 20psi when racing and like 10 when on the street. Gotta love dual stage boost controllers lol
Old Sep 8, 2011 | 05:50 PM
b00sted's Avatar
Absolutely.
Old Sep 8, 2011 | 06:06 PM
Sweet as long as its ok for 10 psi on the street and can get me to my 700rwhp goal ill be happy
Old Sep 8, 2011 | 06:07 PM
what boost controller are you using?
Old Sep 8, 2011 | 06:16 PM
http://www.hksusa.com/products/more.asp?id=3208
Going to purchase this 1 when time comes. Has dual stage boost settings.
Old Sep 8, 2011 | 06:18 PM
Idk if I'm allowed to post that. If not some 1 tell me lol
Old Sep 8, 2011 | 06:46 PM
On mobile version and don't have a computer so can't remove it either if I wasant allowed.
Old Sep 8, 2011 | 09:07 PM
Johnv's Avatar
Don't buy a STD TC 78 for your 383, wait for one of the new ones forced inductions are doing with a bigger exhaust wheel..
I have a TC 78 and had to source a 1.32 ar exhaust housing to get enough flow at the top end, with a .96 ar it would fall over at 5000 rpm, it would drop over 100 hp by 6500 redline.
Old Sep 9, 2011 | 02:41 PM
kbracing96's Avatar
FYI, Forced Inductions told me Turbonetics is only ball bearing on the COMPRESSOR side. The turbine side is still a journal bearing on there bb units... If you have the time, I would wait around for the new 76mm TURBINE wheels come out. A TC78 with with a 76 turbine will make somewhere around a 100 more hp maxed out over the little 68mm wheel
