341 rwhp... i was expecting more
Old Sep 10, 2011 | 02:31 PM
sleepy_boy1's Avatar
Default 341 rwhp... i was expecting more
Hi guys, i have a 2004 gto with a stock 5.3 engine with ls1 heads on it and am running the STS Turbo kit at 10psi, the car made 341 rwhp and i feel it should make much more.. what rwhp should i expect? my AFR is 10.3 at wot with meth
any ideas...
Old Sep 10, 2011 | 03:14 PM
JRENIGAR's Avatar
Damn, I thought my dyno #'s were low. That sucks, Auto or manual? Any spark blow out? Does it feel faster than the stock combo, maybe the dyno wasnt loaded correctly or something? Post pics of the graph and maybe someone can help.
Old Sep 10, 2011 | 03:17 PM
Ghostintheshell's Avatar
Yeah somethings not right with that.
Old Sep 10, 2011 | 03:20 PM
CarsandWomen's Avatar
where is your boost reference from? stick or auto?
Old Sep 10, 2011 | 03:46 PM
dyno was loaded perfect, 4000lbs for a 2004 gto, i have the a4, should i run without meth? im running at 5600rpm with peak hp at 4600rpm.. something isnt right.. no detonation all around with meth,
Old Sep 10, 2011 | 04:08 PM
Frans96SS's Avatar
You mean 5.7 ls1?
Old Sep 10, 2011 | 04:16 PM
projectX's Avatar
Something is def way off here.
Old Sep 10, 2011 | 04:17 PM
TurboAv's Avatar
Converter locked or unlocked? How much timing? Stock exhaust manifolds or headers? What size piping to turbo? Which turbo and AR on exhaust houisng?
Old Sep 10, 2011 | 04:28 PM
i dont know about the converter, timing was 14 degrees, on the WOT area of the spark table, stock manifolds with the STS Turbo kit which has 2.5 inches to the turbo i think..
Old Sep 10, 2011 | 04:29 PM
Originally Posted by Frans96SS
You mean 5.7 ls1?
im running a 5.3 iron bloc with ls1 heads to lower compresion
Professor_speed's Avatar
are you blowing through the converter? any signs of valve float? (what springs valve springs do you have? can you post the graph?
Old Sep 10, 2011 | 04:39 PM
JAX04's Avatar
Again, where is your boost reference at for the wastegate?
Was the boost verified by an external gauge?
the recorded run i with the tuner, ill try and get a hold of it tomorrow, what exactly do you mean by blowing through my converter? i have stocks ls1 valve springs as i do not exceed 5500rpms and i don't think i have valve float
Old Sep 10, 2011 | 04:43 PM
my boost reference is in the vacuum line that goes to the brake booster and my boost gauge is also connected there, that is where the STS kit fittings are provided.. should i move it the intake? would that make any difference? i seem to be hitting 10psi at around 3-4k rpms which seems normal...
Old Sep 10, 2011 | 04:59 PM
HydroStream6's Avatar
Stock valve springs and 10 psi are a no no. Upgrade them.
Does the car have cats on it? Peak hp at 4600 is way off for a 5.3. What cam is in it? Post the dyno graph, you most likely have a couple different problems going on leading to one big mess.
Old Sep 10, 2011 | 05:10 PM
TurboAv's Avatar
I will also echo getting better valve springs.
Old Sep 10, 2011 | 05:20 PM
jeffreycastgsx's Avatar
any ideas...
You have a 5.3 with low compression so dont expect to make a lot of power at just 10psi and that is way rich, dont see how the meth would even help then.
Seems like they tuned way safe, i doubt the meth even help with that little timing and boost.
Why are your revving so low?
Check for boost leaks.
Old Sep 10, 2011 | 05:54 PM
slow67's Avatar
Gingervitis Addict
Most stone stock 5.3Ls dyno around 220RWHP.....
Old Sep 10, 2011 | 08:20 PM
TurboAv's Avatar
I would toss a small cam in it also. Like an LS6, 224, or 228.
Old Sep 10, 2011 | 08:45 PM
OneBad98Z's Avatar
Aren't the 5.3's like 9.5:1 with stock heads anyways?? Defenitely seems off my 4.8 with only a ls1 intake and the early ls2 can and springs makes 490 at 12 pounds and at about 5800rpms, 10.5lbs was 469whp if I remember correctly on 93 octane no meth and timing in the 12-15 degree range depending on how much the burst knock steals lol
Valve springs defenitely seem possible, and meth just seems overkill, my afrs were in the 10.4 range also, so I'm sure you have something holding you back..
