Power Steering pump in the way?
Old Sep 11, 2011 | 06:28 PM
ModularTurbo's Avatar
Default Power Steering pump in the way?
Do you have forward facing turbo headers?
Is your power steering pump in the way?
Do you just want a slimmer engine profile?
Well check this out. We just finished our power steering pump relocation kit.
We will have more pics of all the components included soon.
This kit will also include a custom lines and fittings.
As always it all just bolts right on.
STOCK PUMP LOCATION
CBR PERFORMANCE POWER STEERING RELOCATION KIT INSTALLED
HOW FAR WE WERE ABLE TO MOVE IT
POWER STEERING HOSE KIT
UPDATED PICS OF THE FINISHED PRODUCT:
Old Sep 11, 2011 | 06:56 PM
MUSTANGBRKR02's Avatar
Looks awesome. So I'll bite. What is the price?
Old Sep 11, 2011 | 06:58 PM
We will have better pics and pricing info soon.
Old Sep 11, 2011 | 07:29 PM
Firehawk441's Avatar
Very nice job as always guys.
Old Sep 11, 2011 | 11:51 PM
slownova73's Avatar
x2 for pricing, what about alternator placement on the other side?
Old Sep 12, 2011 | 05:16 AM
Need_a_Camaro's Avatar
In for price as well. I really dont want to lose my ps.
Old Sep 12, 2011 | 07:11 AM
Sarg's Avatar
Also curious about the alternator. Guessing this is ls1 aluminum block? Any chance it would work with an iron block?
Old Sep 12, 2011 | 09:54 AM
SippiSpeedhawk's Avatar
Also waiting on price.
Old Sep 12, 2011 | 10:00 AM
Should work on an iron block but we haven't tried it yet.
Does work with our alternator relocation kit pictured below.
Old Sep 12, 2011 | 11:42 AM
socal's Avatar
just ran into this problem thanks for a solution
Old Sep 12, 2011 | 04:56 PM
Chris@CBR's Avatar
It won't matter if the block is iron or aluminum, the bolt holes that are used for
the water pump bolts on the drivers side is what holds the idler bracket and the
power steering bracket uses the bolt holes in the drivers head.
I know what you're thinking, the iron blocks are missing two bolt holes low on the drivers side. These brackets are not affected by this either way.
Old Sep 12, 2011 | 05:32 PM
98Z28CobraKiller's Avatar
Restricted User
Very nice. It was a huge PITA to get one for LS2Formula. Josh @ KYTP ended up having to buy a few in order to get a run made on them from Shearer to make it worth their time IIRC.
Old Sep 12, 2011 | 06:51 PM
Tiago's Avatar
very nice, Im interested in one.
Old Oct 13, 2011 | 05:08 AM
Did this die? I'm still dreading dealing with this issue.
Old Oct 13, 2011 | 08:38 AM
It's very much alive!
We are just waiting on the custom power steering lines to come in. We should have complete kit pics soon.
Also we are going to make 10 in the first batch. We are accepting pre-orders.
Old Oct 13, 2011 | 08:53 AM
Trl_ws6's Avatar
Can you PM me pricing of it, maybe with your alternator relocation too?! This would be a sick package deal.
Old Oct 14, 2011 | 10:31 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Have you determined pricing?
Old Oct 16, 2011 | 01:59 PM
Sarg's Avatar
Also curious about pricing.
Old Oct 23, 2011 | 08:20 AM
FYI, a pulley from a 94 V6 Corsica is 1.4" smaller than the Fbody pulley, and has the same shaft size. NAPA also stocks a belt that is 1.5" shorter than stock. I have both now, and they work like a charm. If it spins the pump too fast and kills it, then I'll go with manual rack. Until then, this will get me buy under 50 bucks. Pulley= $14, Belt= $30
Old Oct 23, 2011 | 09:16 AM
Professor_speed's Avatar
If you offer the kit lines should be separate, or a build your own line kit for those of us that will not use it in an f body. It would be nice it was moved even more and used a smaller pulley.
I doubt that it will be spun too fast and if it is there a ton of GM's (and other makes) that use the same pump with varying pressure and flow rates, just different reservoirs. pressure can be lowered by cutting the bypass spring ad flow can be adjusted with an orifice.
