Questions on gate placement: PICS inside
Old Sep 12, 2011 | 01:07 PM
madmax4499's Avatar
I bet it will work just fine the way it is. what is the lowest boost your shooting for? your builder is going to have to make a new merge or patch that one. $$$ and time. that gate and pipe are huge. it is going to vent pressure, it might not get you down to 5.psi but i bet it will regulate down to 10-12 psi.
Old Sep 12, 2011 | 03:01 PM
cjmatt's Avatar
it will work. my last turbo kit had a wastegate a foot from the merge on one pipe. the only problem youll have is that you wont be able to run as low a boost number as one with proper location as youre missing out on some flow
Old Sep 12, 2011 | 03:13 PM
Need_a_Camaro's Avatar
The merge isnt cut yet, just tacked there for fitment. We're going to leave it there, and make a crossover pipe to tie into that one. Thanks for all the responses guys. I cant wait to get this thing finished.
Old Sep 13, 2011 | 05:01 PM
Johnmaster's Avatar
MASS seller approved
I spent the better part of a week trying to get my wastegate and dump pipe where I wanted it. Had to move the rest of my pipes to accomodate it. Hope you get it figured out in a way that you are happy with, hard to fit 10 lbs of crap into a 5 lb bag sometimes
Old Sep 13, 2011 | 05:23 PM
mr_biscuitz's Avatar
when the gate opens you are likely going to have a balance issue in the motor since one side will be feeding turbo and the other side will be out to atmosphere (less pressure)
What issues will this cause?
Old Sep 13, 2011 | 06:29 PM
98Z28CobraKiller's Avatar
Restricted User
Here's mine. Looks pretty phallic. This was the original setup. Since then I had to step up to a 60mm JGS as the 44mm Tial was only able to get me to 15 psi with the softest spring. I can get down to 6-7 psi on a 4 psi spring with the 60.
Old Sep 13, 2011 | 09:12 PM
black98ws6ta's Avatar
I would run a pipe from the other side of the merge and y it in..will work good that way.
Old Sep 20, 2011 | 07:32 AM
Here's what we came up with to solve the issue:
Old Sep 20, 2011 | 07:50 AM
Fireball's Avatar
complicated as hell...but really nice looking. bet coping that pipe was a PITA
Old Sep 20, 2011 | 09:33 AM
n97240's Avatar
Nice!! Much better!!
Old Sep 20, 2011 | 09:48 AM
madmax4499's Avatar
that should work just fine. that kind of pipe fitting is very difficult to do. good work. i wish someone would teach me the easy way to fit pipes. "if there is such a thing"
Old Sep 20, 2011 | 10:53 AM
  #32
RealQuick's Avatar
A+
Old Sep 20, 2011 | 11:28 AM
  #33
IKnowtheFuture's Avatar
Oh ya. that looks sweet. good job on that.
Old Sep 21, 2011 | 07:19 AM
  #34
Johnmaster's Avatar
There are tricks of course but nothing easy about it, time and patience, and lots of it. Nice work, should work perfect I bet.
