Questions on gate placement: PICS inside
Old Sep 12, 2011 | 04:30 AM
Need_a_Camaro's Avatar
Default Questions on gate placement: PICS inside
What do you guys think about this gate placement? There wasnt enough room to get the 2.5" pipe on the merge because of the water pump. Is this going to cause creep issues? It's the PTE66 gate.
Old Sep 12, 2011 | 06:20 AM
Fireball's Avatar
when the gate opens you are likely going to have a balance issue in the motor since one side will be feeding turbo and the other side will be out to atmosphere (less pressure)
Old Sep 12, 2011 | 06:37 AM
I figured it was going to give some sort of issue. Could the other bank be tied into the dump and work out okay? I guess changing water pumps could be a last ditch effort to get the dump in the merge.
Old Sep 12, 2011 | 10:31 AM
IKnowtheFuture's Avatar
you could sell that WG and run a mirror image to the other pipe and have two smaller WGs
Old Sep 12, 2011 | 10:54 AM
trav-tech's Avatar
Just build a 2 to 1 merge to the wg 1 pipe from each of the banks.
I thought about that too, was hoping to make this one work. I've been waiting forever to get this thing finished. Would a setup similar to either one of these ideas work?:
Old Sep 12, 2011 | 11:12 AM
y not go down on the merge on the rad side?
Old Sep 12, 2011 | 11:18 AM
RealQuick's Avatar
+1
Old Sep 12, 2011 | 11:21 AM
No room, the pic is deceiving as hell. That's a 2.5" pipe going to the gate. It's TIGHT in there...
Old Sep 12, 2011 | 11:38 AM
SuperZ's Avatar
There are plenty of mustang kits where the gate is on one crossover pipe.Most of them do it because one header commects directly too turbo flange and doesn't have room for a gate on merge.
All of those guys kits work with it that way.
Old Sep 12, 2011 | 11:43 AM
can u take a pic looking down at the front of the motor?
Old Sep 12, 2011 | 11:45 AM
RealQuick's Avatar
I think it will be fine as is, but it is not optimal.
You don't have room to drop it vertically down into the merge (so the wastegate stands up vertical... parallel with the radiator)? See pics for location of wastegate dumping into merge (pipe will be stratight, not radiused)
Attached Thumbnails Questions on gate placement: PICS inside-turbo.jpg
Old Sep 12, 2011 | 11:47 AM
The car isnt in my posession, so I'm going by the word of the fabricator. Here is the only other one I have that shows what you're looking for. It actually does look like there's room on the front.
Old Sep 12, 2011 | 11:55 AM
@realquick- that way would be horrible for controlling exhaust flow...
I would try seeing if you could mount it like I said by the rad
Old Sep 12, 2011 | 12:07 PM
Yeah, I'm going to see if he can do it like that. If not, we'll just tie it into the other side like my awesome drawing.
Old Sep 12, 2011 | 12:09 PM
RealQuick's Avatar
No different then running it the way you said. The way everyone does it (like how you want) has the pipe perpendicular to the flow of the exhaust... which is technically horrible for controlling flow. However, every kit runs it like that, and usually there are no flow control problems
The best way is to have two small pipes inline with the flow merge at the wastegate.
Realistically the turbo setup will have a higher back pressure pre turbo than post turbo, so proper "flow" into the gate isn't a crucial. A pressurized system will vent where ever the opening is.
It becomes more crucial to be inline with the flow if the back pressure is closer to 1:1 or if the wastegate is undersized.
Old Sep 12, 2011 | 12:16 PM
trav-tech's Avatar
Does your merge have a divieder? If not just put it to the middle of the collector on the waterpump side making a 90 and sitting off to the passenger side..
Old Sep 12, 2011 | 12:24 PM
That's the whole issue, there's not enough room between the merge and the waterpump. The pipe for the gate is 2.5"
Old Sep 12, 2011 | 12:33 PM
im just saying it wouldn't have the best control if the air had to make a 180* turn. the air is going to want to go straight into the turbo verses flipping around, especially at the velocity its moving.
Old Sep 12, 2011 | 01:05 PM
RealQuick's Avatar
Agreed.
I think with a 66mm gate, he'd be fine no matter how he puts it.
