11-1 compression + boost = boom?
The key is a good tune and 100% meth injection. I made 580rwhp with a tc76 on 7lbs and I've been running a 76gts now on 8lbs for the last 1000 miles or so. If you're not very familiar with tuning I suggest you get a set of 317 heads. I have done a few 3rd gear pulls that hit 16lbs of boost on accident, after I looked at the log I can't believe it's still alive. But my tune is setup to add a **** load of fuel above 8lbs of boost and pull quite a bit of timing, so I was only around 5 degrees of timing on 16lbs. I've tuned a few boosted ls cars so I've learned a few tricks along the way. Trending Topics
