on3 turbo
Old Jan 13, 2012 | 12:46 PM
  #181
rouseyss's Avatar
I just got off the phone with on3 and they said theres no plans of a complete kit in the near future but their turbo pieces seem to be solid
Old Jan 13, 2012 | 01:10 PM
  #182
RedRocketZ28's Avatar
Are you referring to an Fbody kit or one for your Cobalt? I talked with them last month and was told they had an Fbody on the lift and were working on a kit. Was supposed to be out this month sometime he said. Who knows though, plans always change.
Old Jan 15, 2012 | 05:57 AM
  #183
pronova's Avatar
any one running twins on cammed stock bottom 5.3 with good results?
Old Jan 15, 2012 | 07:35 AM
  #184
Sarg's Avatar
We were about to, but discovered the cylinders had pitting when we went to hone them. Time to find a new block
Old Jan 15, 2012 | 10:18 AM
  #185
pronova's Avatar
which turbos would be my best bet? i want journal bearing , so i can keep price down. i would like them to light easily so car is not a sled! its a 69 f body, tube chassis, turbo 400 , 33-17-slicks.
  #186
rouseyss's Avatar
I was asking about the F-body. He told me they dont have plans for the near future but who knows maybe I talked to one there who wasnt really interested in the business as much as others there are.
Old Jan 15, 2012 | 12:49 PM
  #187
99Ls1fever's Avatar
There are 2 guy I believe that run on3 . Thats too bad i deffinatley thing there is a market for an on3 fbody kit.......
Old Jan 15, 2012 | 03:52 PM
  #188
tripblackls1's Avatar
Considering there is already a cheap eBay hotside available and modular turbo making good kits for cheap I really don't think there is a market for them , there turbos yes but a whole kit not so much
Old Jan 15, 2012 | 03:56 PM
  #189
BLWN1's Avatar
Guess Time will tell...
Old Jan 15, 2012 | 04:36 PM
  #190
rouseyss's Avatar
I dont believe the on3 turbo will work with the modular hotside kit unfortunately
Old Jan 15, 2012 | 06:53 PM
  #191
I don't see why not, its not as if its a large frame turbo ,if I remember correctly its the same size as any other t76 (outside dimensions ) which I believe there kit is designed for
Old Jan 15, 2012 | 07:42 PM
  #192
99Ls1fever's Avatar
I would agree, if i was going to do a LS1 turbo build I would contact josh at Kentuky Turbo... I was just saying that the kit is way cheap and 2300 full kit is pretty resonable
Old Jan 15, 2012 | 07:53 PM
  #193
GarrettT/A's Avatar
I would be very interested in an on3 kit. There is gap between the high end kits and the useless ebay stuff. I believe the mustang kits are 3 grand? Thats half of the other kits are. Come on3, do it!
Old Jan 15, 2012 | 08:17 PM
  #194
the quality of the our eBay kit is on par or better then what on3 offers for mustangs as far as the hotparts go
This is my opinion base off of the few on3 mustangs I've seen and research I've done on them
I'm also a eBay hotparts owner and I all reality there is only two major issues with it , the dp and a few bolt holes needed to be clearanced , I knew this going into it so I've never bothered with the dp and made my own
I can guarantee modular turbos kit is far superior than anything that on3 is going to make and is going to be same price range
I wish they made there kits before I built my car
Old Jan 15, 2012 | 08:50 PM
  #195
99Ls1fever's Avatar
The kits are 2300 for a full kit if you order the forward facing kit with headers and 1600 if you get there gen 1 kit
I am not sure where you get your info, but i have a 0n3 forward facing kit on my 96' Cobra. And the kit's fitment is amazing and is a breeze to install. As I previously stated the things I would improve on are the v bands and add gaskets and copper rtv to all the pipes.
4v kit putting down 600hp plus and runs 10's:
http://www.svtperformance.com/forums...t-install.html
2v forward facing kit:
488hp on a 2v
http://www.moddedmustangs.com/forums...sults-on3.html
http://www.moddedmustangs.com/forums...rbo-build.html
Old Jan 15, 2012 | 09:34 PM
  #196
RedMilleniumZ28's Avatar
iv just started looking at these turbos for my turbo build and read all the pages in this thread and saw alot of people asking about the f-body ls1 kits well as i was searching i found this!
Old Jan 15, 2012 | 10:36 PM
  #197
DavidPHumes's Avatar
Is the ON3 76Mmm .96a/r physically bigger than a TC76 (also .96a/r)?
Old Jan 16, 2012 | 01:46 AM
  #198
ZTwentyAteU's Avatar
a couple small changes on the ebay hotside and it works just fine. New v bands from precision, maybe a cut and re weld or 2, and wrap it, and its pretty nice for 500. Its not really a easy bolt on kit though...but then again, its 500. I've got a on3 ball bearing 76 on a ebay hotside with a/c..its not bad
Old Jan 16, 2012 | 03:47 AM
  #199
WheelsUp84z's Avatar
the on3 is a little smaller than a tc-78. The hotside on my car came off of one for tc78. the dp is a 3.5" outlet vs the 3" for the on3, and when i set the DP up to the exh housing it was about 1/2 off (on3 76 exh housing/unit is smaller).
Old Jan 16, 2012 | 10:53 AM
  #200
rouseyss's Avatar
I called modular performance and asked. They said that theyve never tested it and arent sure it would fit but I am gonna test it out when I order the modular hotside
