Will a 2.5 in intercooler be To restrictive ?
Old Sep 18, 2011 | 11:45 PM
Liftedsilvy's Avatar
Default Will a 2.5 in intercooler be To restrictive ?
I'm thinking of intercooling my nice but space is limited behind the grill so I'm needing a intercooler that's 28-30"x8-9"x3" but the only coolers I can find in that dimension are 2.5" inlet/outlet,so my question is if I go with a 2.5" will it flow enough to not be a problem at say 14-19 psi with a 88mm turbo?
Old Sep 19, 2011 | 04:51 PM
Any info would be great
Old Sep 19, 2011 | 06:34 PM
narx66gmc's Avatar
you can't fit a larger core behind your grill area?
Old Sep 19, 2011 | 08:42 PM
tonytone4143's Avatar
i think you will be fine...
Old Sep 19, 2011 | 09:40 PM
No thats max size there is not alot of room.I wish there was more!!
Old Sep 20, 2011 | 05:55 AM
bourny's Avatar
I had a 2.5" with my t-trim and it wasn't big enough. Wasnt making over 5psi. Upgraded to 3" cooler and piping and made 10psi.
Old Sep 20, 2011 | 08:59 PM
Ok thanks...ll have to figure something else out maybe mount it under the car flat but im worried it wont have much air flow......
Old Sep 22, 2011 | 10:57 AM
kbracing96's Avatar
His setup is a S488 blow through carb on a 408 in a 63 Nova, so the intercooler isn't as big of a deal. I would get the core that you can fit even if it has 2 1/2 in/out and then take it to a welding shop and have them cut the in/out off and weld in some bead rolled 3" tubes to the end tanks.
Old Sep 23, 2011 | 02:11 PM
Thanks Kyle.
Old Sep 24, 2011 | 10:44 AM
Tzion_ben_Arthur's Avatar
do superchargers create less heat... say D1SC at 12# to 14#
Old Sep 24, 2011 | 01:05 PM
nxfirebird's Avatar
then i wouldn't even run one with the carb. even pump gas has about a 50 degree temp drop though it.
Old Sep 24, 2011 | 01:13 PM
Speed Freek's Avatar
Maybe on E85...not regular fuel, especially of the manifold is heat soaked. Atomization does cause cooling (windchill) but not that much.
IN the case of the OP, like already said, just cut the 2.5 elbows off and weld some 3" ones and and you have what you need, only as long as the core can support the flow of your motor under boost at maximum rpm without bottlenecking.
Have you calculated the flow of the motor at "X" psi at max rpm? Then look at the spec for the core if even available, usually they arent if its a universal IC.
I usually build my own IC, I buy the proper core(s) and build the tanks and weld on the elbows where I need them, this way I know it will flow properly for the system.
Old Sep 24, 2011 | 04:30 PM
nxfirebird's Avatar
Originally Posted by Speed Freek
Maybe on E85...not regular fuel, especially of the manifold is heat soaked. Atomization does cause cooling (windchill) but not that much..
haven't done an LS, but on a BBC 540 with an M3 at 10lbs on the dyno, it did. running 92 pump gas.
Old Sep 24, 2011 | 08:22 PM
I havent calculated it,Its a 408 running anywere from 10-20 psi The intercooler flows 700 cfm....
Old Sep 25, 2011 | 12:26 PM
lsturbo's Avatar
It would restric alot I had one with 3" in and out about same size on my lq4 76mm turbo 13psi changed to a water to air with out tuching boost and it was at 18psi
