Air Filters.
Old Sep 24, 2011 | 06:19 PM
LASTLS1's Avatar
6 Second Club Moderator
Default Air Filters.
At what point does everyone take their air filters off? Does anybody have any firm data when they become a restriction?
Old Sep 24, 2011 | 06:24 PM
19kiloz28's Avatar
Confused are you talking about clean/replace or running without an air filter?
Old Sep 24, 2011 | 06:31 PM
LASTLS1's Avatar
Take off, run without.
Old Sep 24, 2011 | 09:45 PM
onfire's Avatar
Coal Mining Director
When I was running 155mph at the track last year I did a back to back run with/without K&N's on the twins...did not change 1 mph. I'm now at 165 and need to retest. Somewhere it will become a restriction. I was very impressed with the small K&N's...I even added two Turbonetics Bells and it stayed 155.
Old Sep 25, 2011 | 02:37 AM
qqwqeqwrqwqtq's Avatar
I believe we've discussed this before but if it picked up even 1mph at the point of you maxing out the turbo's I would be very surprised.
Old Sep 25, 2011 | 06:56 AM
stevieturbo's Avatar
Whilst googling stuff earlier today. I noticed that Camaro Andreas runs a pair of pretty small filters on his turbos.
If he runs them when racing, it's pretty clear that most road going vehicles should have no concerns about using an air filter.
But I did read his was dyno'd with them on. SO if it's making well into 4 figures....again, only a lunatic would not fit an air filter.
Old Sep 25, 2011 | 09:56 AM
LASTLS1's Avatar
It looks like the filters are showing signs of collapse?
Old Sep 25, 2011 | 10:03 AM
where ?
Old Sep 25, 2011 | 10:11 AM
LASTLS1's Avatar
There's alot of lunatics around. Because I'm the only guy who runs them in my class. lol The wire screen has creases in them that I haven't noticed before.
Old Sep 25, 2011 | 10:16 AM
None of the filters last forever, you can see pics of Andreas' filters here. Just a regular smallish barrel style filter
http://www.planetlsx.com/vehicles/Ne...3_203_MPH_/163
I cant see why anyone would ever want to run without a filter, unless they have so much money they dont care about debris going into the turbo/engine.
Or if it's purely for looks where the turbo intake is forward facing.
Old Sep 25, 2011 | 10:23 AM
LASTLS1's Avatar
Thanks for the info but I'm looking for someone who has done some testing with them in the 2000hp range.
Old Sep 25, 2011 | 10:29 AM
I'd say he isnt doing too badly, and they are very small filters. Just fit bigger ones. Or build yourself a large custom airbox to take large panel style filters
Old Sep 25, 2011 | 11:02 AM
Stumped1215's Avatar
I would check around on yellow bullet.
Old Sep 25, 2011 | 05:13 PM
Tiago's Avatar
I took mine off last year to get faster spool and more boost at the line on the TB without changing converter, it helped a couple of psi on the TB, not sure how much it helped on the spool time, but I never bothered putting them back in.
Old Sep 25, 2011 | 06:27 PM
KILLER-LS1's Avatar
It sounds like most of you are running twins, which means you are running similar sized filters on smaller turbos.
Id like to know if my 7" long by 5" base cone filter is "too small" for my 91mm making close to 1k rwhp. thats the biggest filter that k&n makes, and is also the biggest thing that I can fit in the confined space.
anyone have any info on this?
Old Sep 25, 2011 | 07:39 PM
Nitroused383's Avatar
Andreas runs BMC filters, which are very high dollar filters that formula 1 cars run. 2000 hp is about 200 lbs / min or about 100 lbs / min per turbo. 100 lbs / min = 1450 cfm, I've been doing a little research and haven't found anything filters that flow much over 1250 cfm.
Old Sep 25, 2011 | 09:45 PM
LASTLS1's Avatar
I did a little test at the shop and there's no doubt they restrict air flow. I'm just not sure what it's worth in hp at full boost or in spool time. Thanks for your research!
Old Sep 26, 2011 | 02:58 AM
K&N Make a 6" opening, 8" diameter x 12" tapered cone
Old Sep 26, 2011 | 09:11 AM
Tiago's Avatar
I have one that is 6" opening, 8" OD, x 8" LG, that is making 1500 RWHP with no restrictions as far as the dyno tells us...
Old Sep 26, 2011 | 10:24 AM
LASTLS1's Avatar
What about added back pressure?
