chinese turbo track times
Old 09-19-2012, 02:45 PM
  #221
Moderator
denmah's Avatar
It's a 68mm gt45 from vsracing
What else do you wanna know?
It's a stock 4.8 with a ls9 cam 20lbs of boost valve springs and everything else is stock
It had a 4l80e trans with a circle d triple biller lockup converter
Foot brakes 1.6x
Old 09-23-2012, 01:47 AM
  #222
Ferocity02's Avatar
For a 5.3L T56 truck, looking for ~600hp but with good usable power in the mid-range, would you recommend the On3 T76 or the GT45? The GT45 has the bigger 77mm turbine side so it won't choke out as soon, but only a 68mm compressor. While the On3 unit has a small 65mm turbine but the larger 76mm compressor. I'm torn between these two!
Old 09-27-2012, 01:33 AM
  #223
Kurtis2short's Avatar
Question I have a built 6.0 stroke stroke but warhawk heads and a vodoo 294 cam that's range from 2900 to 7400 and with my hi ram Holley I plan on taking it to 7400 do u think one of these in a single would push around 900 hp or do u think even if I when twins with the on3 would they choke out at that rpm range
Old 09-27-2012, 05:06 AM
  #224
Sarg's Avatar
I think you would be maxing it out before 6000 rpms with a stroker motor. Twins I think you will be fine.
Old 09-27-2012, 08:42 AM
  #225
oneoverwrx's Avatar
It seems out of breathe by 6000ish on my 4.8
Old 09-27-2012, 01:44 PM
  #226
I talked to on3 today and 3 to 4 months they're thinking theyll offer a 88 mm single so I think I'll wait and get that it should be plenty and hoping it won't run out of breath i asked him what the specs will be and he said hell have to get back to me on them
Old 09-27-2012, 05:04 PM
  #227
Sarg's Avatar
I think one of the other Chinese turbo makers (or Brazilian as the case may be) was about to release one as well.
Old 09-27-2012, 08:37 PM
  #228
Moderator
denmah's Avatar
yes i think magnum was supposed to have an 88 already or same story, getting one out eventually.
Old 09-28-2012, 06:21 AM
  #229
TURBO8's Avatar
Can you buy the gt45, and then buy a t6 housing? What's the most ho you can make with the gt45?
Old 09-28-2012, 09:40 AM
  #230
oneoverwrx's Avatar
I think 750ish through a 6spd on boost only will be maxed out. I may be severely wrong but we are trapping 143-146 on 10-13psi @2900 lbs. and still spinning some. This turbo will go in the 150s at my weight if we can put it down. I can imagine what 20psi would be like if it stayed attached to the ground.
Old 05-18-2013, 01:48 PM
  #231
lsxmalibu's Avatar
new look and still running strong, still running the cheap turbo and wastegate/Bov.
Old 05-19-2013, 12:03 AM
  #232
360demonRT's Avatar
Gorgeous man. Can't wait til I get enough extra money to work on my 79.
Old 05-19-2013, 06:56 AM
  #233
SSZ
SSZ's Avatar
Looks great. What engine cover is that?
Old 05-19-2013, 07:22 AM
  #234
lsxmalibu's Avatar
I made it, its the newer style cover, like 2007 and up. filled in the front and side hole,
Old 05-19-2013, 07:31 AM
  #235
HPbyGD's Avatar
Is there some place where there is some info about what materials to use when modifying a cover ? I tried to search for some tips but didn't find any thing.
Thanks GD
Old 05-19-2013, 08:13 AM
  #236
lsxmalibu's Avatar
I fiberglass thin metal behind the hole, then use some " kitty hair" bondo for the front.
I have this smaller one thats smoothed out and filled in for sale
https://ls1tech.com/forums/parts-cla...-modified.html
Old 05-19-2013, 10:14 AM
  #237
HPbyGD's Avatar
Thanks lsxmalibu
Thanks you for the information. Also love you wagon !
GD
Old 05-30-2013, 08:27 AM
  #238
lsxmalibu's Avatar
no prob
Old 05-30-2013, 10:57 AM
  #239
MonmouthCtyLS7's Avatar
Got the Cxracing Gt45R ball bearing turbo with the 76.6 compressor wheel and 77.4 Turbine wheel. Numbers coming soon. Throwing this on a forged 5.3 so I'm gonna push it.
Old 05-30-2013, 02:36 PM
  #240
Moderator
denmah's Avatar
2000 silverado 2500
6.0 4l80e 9.5 rear all stock 213k miles
chinese 80mm from VSracing
11.9 @ 121mph on street tires 5060lbs
