new to turbos few questions
Old Oct 2, 2011 | 11:09 PM
Gfleck047's Avatar
Default new to turbos few questions
As you read above this is my first time playing with a turbo in my car. i have a 84 notch i picked up for cheap and wanted to do a turbo ls1. but which one. 4.8 5.3 5.7 6.0... everyone i tried talking to shoved me aside and didn't wanna help or give advise. i just don't know where to start should it be injected or carb. the truck 6.0 iron block or the 5.3 alumni or iron block. if anyone would help a first timer out would be much appreciated
Old Oct 3, 2011 | 06:51 AM
LS1NOVA's Avatar
Id use a L33 alum 5.3 to save weight. Use injection.
Old Oct 3, 2011 | 10:15 AM
Gfleck047's Avatar
Wouldn't the iron 6.0 handle the boost better bein iron?
Old Oct 3, 2011 | 12:57 PM
LS1NOVA's Avatar
It doesnt really matter unless your shooting for big power numbers. What are the goals?
Old Oct 3, 2011 | 11:14 PM
Gfleck047's Avatar
I am lookin for 600 to the wheels that will last
Old Oct 4, 2011 | 12:02 AM
craig382ci's Avatar
If 600whp is all you're looking to make, then I would go with the 5.3 alumni. I have always been told from day one. Choose your turbo to fit your HP goal and build your motor are it.
Old Oct 4, 2011 | 08:03 PM
turbo iroc's Avatar
I'm running a blow thru carb, works great and much cheaper than injection. I already had the carb, all I needed was msd 6010 box ($300) and carb intake (used200). If you have a carb already you can modify it for blow thru for next to nothing.
Old Oct 5, 2011 | 12:53 PM
Gfleck047's Avatar
What blow through are u running? what set up do u have?
Old Oct 5, 2011 | 11:25 PM
turbo iroc's Avatar
I'm running a Qft 750 ban carb on a 402ci iron block with l92 heads and 88mm Turbo.
