Stage I Incon - What is Max Boost?
Originally Posted by cablebandit
44lb/min...Harlan, doesnt that equate to like 800 rwhp with both turbos? What do you think the limit is on the Incons?
Gotta remember you lose alot to heat at that point. It just won't take the same spark advance on you start to heat the air that much. Yeah the flow is there, but you can't make the same power. 750 in a manual is probably about the limit.
Just to bring this thread back to life ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
What rwhp do you think the Incons will do ( Stage 2 ) on a 370ci iron block, stock ls1 intake, 222/284 .560/.560 cam, 6.0L 73cc TEA heads, 8.7:1 CR?
- Dug
- Dug
- Dug
- Dug
55lb injectors maxed out on stock PCM. At the time there was no acceleronics box. The car may get a FAST system in the future and bigger injectors. I will bet on 800+ RWHP through the automatic.
