Need help with cam size for a turbo 4.8
Hello everyone,
I'm kind of new to the site first off, but not new to the car game. Currently I am in the process of building a 4.8 turbo to go in my 88 mustang. I was going to use a Z06 cam but can't find one at a price I like. So my next choice was a used turbo cam but again none for a price I liked. So I'm deciding to go with a custom grind cam for my set up unless there is someone who make a good out of the box cam that will work for my set up. I have no clue what cam sizing I should use so essentially I'm looking for someone who could spec me out a cam. I'm looking to pull out somewhere between 6-700WHP I will spin the motor up to 6,500. I was thinking something in the neighborhood of cam like this 216/224 .050 duration .565/585 lift 116 LSA
Here is my set-up:
Stock 4.8 rotating assembly
ARP head studs and rod bolts
Ported 241 heads with patriot gold spring kit and stock rockers
Stock ported throttle body
LS1 intake
80lb injectors
6.0 truck manifolds
tc78 turbo
th400 trans built with a trans brake
3.27 or 3.55 gear in the rear
thanks for the help guys
Here is my set-up:
LS1 intake
80lb injectors
6.0 truck manifolds
tc78 turbo
