Confused. Vented or sealed catch can?
Exactly. A checkvalve/ PCV (one way... not orifice) valve between the top hose off the catch can and the Intake Manifold will do it. Actually, for boosted apps, you should cap the line off the TB. Otherwise that's a boost leak straight to the crankcase. Not good and will add more pressure into the crankcase. Not needed.
(Nice Pic by the way, whoever's it is.)
If you dont want the gasses back in your engine run them out the exhaust. I just used the factory check valve off the air pump system and attach it the sealed catch can. It constantly generates vacuum to the canister.
Might not be a bad idea to connect a line from passenger front valve cover to intake manifold with a one way check valve to allow the crank case to breathe when not in boost. It would draw fresh air back through your catch can and help get rid of the crank case vapors. Just a suggestion.
I'm having a pretty bad oil leak, and the pcv plumbing is actually rotted in two spots, one being in the back. They are saying this is probably where it's coming from. I was planning on just swapping to the new 04+ ls6 pcv system, and call ing it a day.
Is the oil shooting up in that area on the driver side head accurate? If so, I can imagine this being why I have quite a bit of oil dripping. It's not the OPSU, or cam sensor either, because those were replaced thinking that's what the problem was initially.
Also they sent a breather to replace the oil cap that has a one way check valve on it.
I do not want oil going into my intercooler or intake or oil. Thats what this is starting to look like is going to happen. I thought Rx was going to be better than this, but it looks like its just for show.
The can itself apparently has dual check valves in it based on what I am told. Is there a way to fix this, or do I just need to chunk it and get with Dave?
i8urfrd i am not familiar with their one way valve for the oil cap, but if they sent it you should use it!
im also not familiar with the insides of their can set up, but there's more than one way to skin a cat!
hooking direct to valley cover vs. valve cover is pretty restrictive 'exit' for any high hp blow by. i run off each valve cover which is basically unrestricted. and run the valley cover separate to the sc/turbo inlet if available.
Diagram of current routing plan
It seems to me you could add a T between the two rears and get a little bit better flow without compromising it, but maybe not. I hate PCV.
Cutaway and discussion of the can.
