Confused. Vented or sealed catch can?
Old Jan 16, 2013 | 09:05 AM
  #61
Zmg00camaross's Avatar
Originally Posted by MIGHTYMOUSE
ive had several ask about -an fittings.
best bet is you buy the fittings and tell me what NPT thread is on the back side, and ill ship the can ready for you to screw them in
Sounds good, need a price quote then and I will get your info on the fitting
Old Jan 16, 2013 | 09:58 AM
  #62
GMCtrk's Avatar
have a valley cover?
Nope.
Mine only came factory with 1 port drivers valve cover to intake and a line from the TB to the passenger VC.
Old Jan 16, 2013 | 11:53 AM
  #63
MIGHTYMOUSE's Avatar
gmc i have done some with no fresh air inlet before. let me know when you get the can and will work it out
should still work fine but if it draws too much we can always cap one of the can ports
Old Jan 16, 2013 | 01:45 PM
  #64
edge04's Avatar
work in progress
what would be wrong with just having a filter on the valley cover?
Old Jan 16, 2013 | 02:07 PM
  #65
unmetered air if you use a maf
also under high winds (wide open or in boost) there is a draft at the throttle body if n/a, and below atmospheric pressure in front of the tubo/sc that will provide additional scavenging of the crank fumes.
Old Jan 16, 2013 | 02:31 PM
  #66
stealth355tpi's Avatar
MM can I get a pm on a can too, which options is there? Looking to use it on my procharged ls1. I understand your picture with how to run the lines but what about check valves and pcv valves, where's the placement of these to work properly?
Old Jan 16, 2013 | 03:10 PM
  #67
pcv valve is included, mounted in the can. nothing else is necessary other than hose and mounting location of your choice, i strongly reccomend NOT attatching it to the cylinder head.
here's a common location
Old Jan 16, 2013 | 05:04 PM
  #68
blake b's Avatar
What sizes of hoses do you recommend?
Old Jan 16, 2013 | 05:15 PM
  #69
pictured there is 3/8 i think, or 5/16
Old Jan 25, 2013 | 12:43 PM
  #70
GMCtrk's Avatar
Who is running a catch can between the turbo air filter and valve cover?
I'm concerned about pulling oil into the compressor when in boost.
Old Feb 20, 2013 | 03:41 PM
  #71
ryanzcastro's Avatar
In this picture, why is the rear vent on the passenger going to the top throttle body. I have seen the front passenger nipple go to the top throttle body in the Saikou Michi and Revxtreme set ups. Any reason for this? Also is the stock PCV still needed in this set up? I am NA btw.
Old Feb 21, 2013 | 08:17 AM
  #72
the line out of the top of my can is a metal boost proof pcv valve. stock valve no longer needed.
for the catch cans i prefer to pull from the valve covers on a diagonal, so if accelerating hard or braking hard, one is always open (not flooded with oil)
