Confused. Vented or sealed catch can?
Old Jan 10, 2013 | 10:34 PM
  #41
conan's Avatar
Going to re do my pcv this winter.
Old Jan 11, 2013 | 01:08 AM
  #42
My6speedZ's Avatar
I went through alot of PCV issues myself this thread is a great resource.
Dave can I get a PM on those catch cans?
Old Jan 11, 2013 | 08:51 AM
  #43
a-low's Avatar
Me too please!
Old Jan 11, 2013 | 09:26 AM
  #44
djfury05's Avatar
Interesting.. might need one of these to replace the RX can I have now
Old Jan 11, 2013 | 09:44 AM
  #45
LILHEMI's Avatar
in for reference. gonna need one of these soon.
Old Jan 11, 2013 | 11:12 AM
  #46
My6speedZ's Avatar
HAHA, my thoughts exactly I have the Morris catch can and now I want one of the ones David is pimping.
Old Jan 11, 2013 | 11:44 AM
  #47
MIGHTYMOUSE's Avatar
im a couple weeks backed up at the moment.
https://picasaweb.google.com/1144453...chCanBoostVent
follow up with me then on pm sorry guys!
Old Jan 15, 2013 | 12:08 PM
  #48
these are leaving today
Old Jan 15, 2013 | 12:22 PM
  #49
LT1RAY's Avatar
Originally Posted by LT1RAY
Buy the can from mightymouse, run a line from each valve cover to the two bottom ports on the catch can. Run the top port on the catch can to the intake. Cap the TB and the rear port on the passenger side valve cover. Done. It's cheap too.
With the can setup like this (for forced induction), here are the results.
https://ls1tech.com/forums/forced-in...n-results.html
Old Jan 15, 2013 | 01:21 PM
  #50
RedRocketZ28's Avatar
Is this setup alright to run? This is what I currently am using. MightyMouse, if your can would be better to use, I would consider buying one.
Old Jan 15, 2013 | 04:36 PM
  #51
67Firebird455's Avatar
I just got one of MightyMouse's catch can units with a check valve for boost. Great piece, especially for the money. I highly recommend it.
Old Jan 15, 2013 | 05:06 PM
  #52
4kiro's Avatar
MightyMouse I bought you're can sometime ago. How should I set it up for a procharged Ls1. The top port goes to the procharger bottom two ports for the front of each valve cover?
Old Jan 15, 2013 | 05:16 PM
  #53
LT1RAY's Avatar
Run a line from each valve cover to the two bottom ports on the catch can. Run the top port on the catch can to the intake. Cap the TB and connect the rear port on the passenger side valve cover to the inlet of the turbo/supercharger. Done. It's cheap too.
This setup is straight from mightymouse. I ran it like this with my Vortech setup and it worked great
Old Jan 15, 2013 | 06:18 PM
  #54
4kiro's Avatar
Lt1ray thanks. What line do you use to the can. What do I do with the line that goes to the procharger?
Old Jan 15, 2013 | 06:19 PM
  #55
work in progress
Old Jan 15, 2013 | 07:42 PM
  #56
GMCtrk's Avatar
MM what about those of us who only have one port on the passenger valve cover (truck)?
Old Jan 15, 2013 | 08:51 PM
  #57
have a valley cover?
Old Jan 15, 2013 | 09:15 PM
  #58
Zmg00camaross's Avatar
MM I have valve covers with -10 an fittings. Can you build your can with AN fittings
Old Jan 15, 2013 | 09:51 PM
  #59
ive had several ask about -an fittings.
best bet is you buy the fittings and tell me what NPT thread is on the back side, and ill ship the can ready for you to screw them in
Old Jan 15, 2013 | 10:15 PM
  #60
LT1RAY's Avatar
Originally Posted by MIGHTYMOUSE
work in progress
If it is on a LS1 (non LS6 valley cover), the rear port on the passenger side valve cover would connect to the TB (NA setup). If your boosted, the rear port on the passenger side valve cover would connect to the filter located on the head unit (turbo & supercharger) and cap the TB.
Hopefully the picture he just posted helps. I'm sure he's working on a few more diagrams for all the different setups.
