whats needed for tt build
Old Oct 24, 2011 | 08:11 PM
ktm8125's Avatar
Default whats needed for tt build
iam wanting to do a twin turbo but no clue were to start help needed thanks.
Old Oct 24, 2011 | 08:18 PM
Ls2SilverBullet's Avatar
I'm curious to know ALL of what is needed because I want to TT mine in the future.
But before someone who knows what they are talking about asks you, I will:
Need ALOT more details... What is the car? motor? trans? desired hp? desired boost? budget?
Old Oct 24, 2011 | 08:20 PM
ktm8125's Avatar
5.3 planning on pushing to limits so 750-800 and a 400th
Old Oct 24, 2011 | 08:23 PM
ktm8125's Avatar
and the car is my pink 98z
Old Oct 24, 2011 | 09:04 PM
WheelsUp84z's Avatar
This should get you started.
2 turbos of your choice (I recommend calling a sponsor to spec them for you)
2 wastegates (To match turbos, also see a sponsor)
Blow off valve
cold side piping and couplings/clamps
Intercooler* Optional but recommended
hotside pipings and manifolds
downpipe/exhaust
Oil feed and drain lines for turbo
fuel system..pump(s),injectors, regulator and lines (stock wont be quite enough)
2.5 bar or greater MAP
Some sort of boost controller(manual or electronic)
Vacuum lines
TH-400 will require a specific flexplate, and you'll need a turbo spec'd converter. Then add in a new driveshaft. If its a manual valvebody i'd reccommend an aftermarket shifter.
that much power you can forget a 10 bolt holding up, so plan for an aftermarket rear as well, and a few adjustable suspension pieces at minimum..Tq arm, lca's and phb.
That just a basic list...essentially take you projected cost and mulitply it by 2, thats how much it's probably gonna end up costing.
Old Oct 24, 2011 | 09:09 PM
ta02zx10r's Avatar
american express gold card and no buyer's remorse for starters lol
On a serious note: Get a plan first and know exactly what you want and what you are willing to give up to achieve the goals.
Old Oct 24, 2011 | 09:12 PM
narx66gmc's Avatar
Adding to wheelsup list.
Tuning software
3hours of dyno time
A very good tuner guy
Old Oct 24, 2011 | 09:13 PM
narx66gmc's Avatar
Tuning software
3hours of dyno time
Oh, yeah, read about 150 build threads in this forum before u buy anything.
Old Oct 24, 2011 | 09:30 PM
mpatton's Avatar
^^^^^ read read read read read. Lol
Old Oct 25, 2011 | 04:37 AM
98Camarod's Avatar
coolant hoses, boost referenced regulator, more fueling, stood up radiator, abs delete, fuse box relocation, battery relocation, different electric fans, bunch of time, and bunch of money
Old Oct 26, 2011 | 10:46 PM
ktm8125's Avatar
i have alot of time the money is a problem iam only 17 so i probly wont drive the car till after my 18th birthday but it will be well worth the wait
Old Oct 26, 2011 | 11:05 PM
eviltwin_1987's Avatar
How much money do you have to spend?
